S-Works Venge 2019
andreas
by andreas
They add more spokes to the disc wheels due to the increased forces around the hub from braking, so it's a bit surprising to see the varying amount of spokes from the different manufacturers. Light-bicycles even offer 28 spokes afaik.
Anyway, gonna try out the CL50's to see how it works out. Ordered some blingy decals from Speedydecal.com today :)
rammst
by rammst
Tarmacian wrote:
Tue May 07, 2019 7:57 pm
anykarthik wrote:
Mon May 06, 2019 9:04 pm
Darceking wrote:
Mon May 06, 2019 10:46 am
Byskov wrote:
Thu May 02, 2019 6:12 pm
Hey,
can I ask for your measurements? Im looking to buy a Venge without the possibility to try it first (Crazy demand) and I think I'm between a 56 and a 58. I'm 183 cm.
Hey mate - I am 191cm My brother is 183cm and he went a 56cm venge and has been riding 58cm bikes for the last few years, he said he wouldk never go back to 58cm again.
56cm sounds right for a 183cm height. But that said, body proportions matter. For example, I'm 177cm and ride a 54cm venge with stock 100mm stem. I have long legs (88cm inseam) and a short torso. So a 56cm would be too reach-y for me. The 54cm with spacers works well (saddle drop is 11cm).
I’m 184cm and was advised a 58 in my Specialized Concept Store. Problem is the longer reach. I ride a 56 SL5 with 3 spacers and 10cm stem. My drop is 115mm and saddle height 795mm.
Because lack of flexibility it would be nice to sit a bit more upright. Maybe a 56 with al the spacers in place would be an option. Anyone knows the total stack height of a 56 with al the spacers under the stem?
I need to know this too. A 56 size with 80cm saddle height how much is ther drop?
robeambro
by robeambro
rammst wrote:
Thu May 09, 2019 9:02 am
Play with bikegeocalc.com and input all the relevant data.
I think this link should still have my SL size 56, to give you an example: https://www.bikegeocalc.com/#6Tarmaca0b ... 170G30H30Z
rammst
by rammst
robeambro wrote:
Thu May 09, 2019 2:32 pm
sorry but i dont understand this web, to know the drop. If someone has the 56 size and can measure from the ground to the handlebar....
andreas
by andreas
Press "measure" on the provided link.
MNX1024
by MNX1024
Is it possible to leave spacers on top of the stem?
anykarthik
by anykarthik
MNX1024 wrote:
Fri May 10, 2019 4:20 pm
Nope. Not if you want the clip-on top cap to stay on. It would look hideous without that cap
MNX1024
by MNX1024
anykarthik wrote:
Fri May 10, 2019 4:40 pm
Thanks. Guess mine would be hideous for a while. Don't want to shoot myself in the foot by lopping off too much of the steerer tube before I dialed in my fit.
ill principe
by ill principe
There is a special clip-on top cap that allows spacers above included in frameset. Not as good looking, but way better than no cap at all while adjusting fit.
andreas
by andreas
The Sagan edition seems to have a cover that allows it to be uncut?
Bigmac
by Bigmac
andreas wrote:
Fri May 10, 2019 6:42 pm
As far as I know all the Venge bikes and frames come with 2 covers, one allowing you to have an exposed top cap, the other with it concealled
blehargh
by blehargh
Bigmac wrote:
Fri May 10, 2019 7:27 pm
Yes it does come with both covers. I've heard the one that completely covers the the top cap has a tendency to fall off - you end up hitting it with your knee or some such.
andreas
by andreas
Ah, excellent then Supacaz Star Capz can be used to bling up some more :)
lukas456
by lukas456
While traveling and having my Venge back in the car, the frame had a contact with some plastic thingy on my bag. Any idea how to get rid of that?
