If you look at it you'll see it's a barrel type clamp so each post is definitely either 20mm or 0mm, not flippable.
S-Works Venge 2019
3.5W at 30kmh.TonyM wrote: ↑Tue Jul 03, 2018 4:47 pmLooks like 0.01 CdA advantage. If done at 30 mph (48.28 kmh) then for a cyclist riding at 18.64 mph (30 kmh) it would mean a saving of 3.47 watts of power to apply on the pedals (at 20 mph a saving if 4.29 watts). Humm, an advantage definitely but not significant for a road race except in the final sprint or for small riders with a lower FTP.
Given that (they say) the Tarmac rides and climbs better than the Venge, for 99.9% majority of riders, including Pros isn’t the Tarmac the best option? I would leave the Venge to a few selected flat stages where sprinting is the main goal.
I agree that the Venge is sexier, but the SL6 discs with CLX50 is also quite pretty and definitely more understated.
I keep going back from Venge to SL6, and from SL6 to Venge...can’t make up my mind and think that at 69kg the SL6 might be the better bike for me. I am good on the flats but I excel on rolling hills.
I know it’s splitting hairs. And a nice problem to have!
Yeah. Read that article about the 18mm spacers. I have about 18 of headset sticking out on my current bike and zero spacers.majorhunadadun wrote: ↑Sat Dec 15, 2018 1:48 amblehargh wrote: ↑Fri Dec 14, 2018 4:59 pmLol - it's an old bike so measurements are hard to come by accurately. Think the stack is around 575cm and reach in in the 410mmblehargh wrote: ↑Fri Dec 14, 2018 4:59 pmLol - it's an old bike so measurements are hard to come by accurately. Think the stack is around 575cm and reach in in the 410mm
Okay well the 56 is 555 STACK, 398 REACH. That gets you 2 cm lower. You can always put a longer stem on. These particular bikes have a longer seatpost option so people can go with smaller than usual bikes to get more aero. I would always go smaller. I quoted the article below.
https://granfondo-cycling.com/specializ ... 9-on-test/
Specialized Venge 2019 – Geometry
Despite different measurements for its stack and reach, you should have a similar race-led position on the S-Works Venge 2019 as you do on the S-Works Tarmac SL6, achieved through the new Venge’s 18 mm minimum spacer height in the headset cup. The Tarmac SL6, on the other hand, works with a 10 mm higher headset and a longer stem to get the same position. The Venge 2019’s seatpost comes in two lengths (300 mm or 390 mm) and two off-sets (0 mm or 20 mm). The Di2 junction box has been smartly housed in the seatpost.
The 58 stack is 581mm plus the 18 spacers seems like it would be too high already without much option to go lower.
Grrrr
I'm looking to order a purple Venge Pro disc Soon. However instead of di2 it'll be with Etap + ultegra rotors. Any idea Of What the weight might be?
BMC Granfondo 02 105
Scott Scale 940
Boardman CXR 9.4 cxr CX/gravel mongrel
Btwin 540
Specialized Venge Pro Disc
Scott Scale 940
Btwin 540
Campervan: A size 52 is 7,62kg out of the box with Ultegra. If you're going full etap with crank and cassette maybe like 7,4kg or something.
/jonas l
http://instagram.com/jonaslundb
Has anyone tried any of the lighter cassette offerings with DA di2? Rotor Uno? Omni Racer? Curious on shift quality with the Venge specifically?
Thanks you. I'm looking at a purple pro disc in the new year. However I find di2 fiddly so the shop will swap the di2 for etap.
Scott Scale 940
Btwin 540
Scott Scale 940
Btwin 540
hi guys, im looking for a garmin mount to fit on the aero fly II handlebar and stem from the 219 Venge. Obviously specialized do one but are they any other after market options out there that will look sleek with this stem/bar combo?
- Moderator
The slim Pro version of the K edge mount may work?
Using Tapatalk
I've been looking at the UK market myself as I know few websites from there and I'd ordered few items before. Both have them in stock. If you know the place you're going to stay at (or someone from the forums that could possibly arrange the shipment to his/hers place) you should be able to send them there.
https://www.sigmasports.com/item/Specia ... -2019/J5K7
https://www.specializedconceptstore.co. ... -frameset/
Alternatively, you could try and order them to be delivered to your home address.
AFAIK these framesets are pretty scarce here (in Central Europe) - I have to wait until March myself
With the holidays upon us delivery won't make it on time. If I can get it in Germany I will also be able to clain the VAT back.lovemyway wrote: ↑Fri Dec 21, 2018 12:26 pmI've been looking at the UK market myself as I know few websites from there and I'd ordered few items before. Both have them in stock. If you know the place you're going to stay at (or someone from the forums that could possibly arrange the shipment to his/hers place) you should be able to send them there.
Any idea who might have it?
This is a dealer over there, but all sizes appear to be out of stock there too until week 8 or so. You might give them a call to check.greenamit wrote: ↑Fri Dec 21, 2018 12:17 pmHi everyone,
I'm looking to buy Grey/Yellow frameset 56cm. Since my local specialized dealer won't have any for few months I am looking for other alternatives.
I am going to visit Berlin in early Jan 2019. Maybe soneone here knows/can help how to source this frameset?
Thanks
https://nanobike.de/Specialized-S-Works ... ow-edge-fa
Ordered my Black frameset in Canada end of July.. I didnt get it until 1st week of November.. I can assume it'll be similar over in Europe..
Hi everyone.
Does anyone know how to attach a Wahoo Elemnt Bolt onto the Aerofly Bars? From looking at the photos that have been posted, it looks like it’s mounted from inside the bars- can anyone clarify or post a photo? And do you need a special mount separate to the one that comes with the Bolt?
Thanks!
Thanks!
