S-Works Venge 2019
Maddie
by Maddie
steamroller wrote:
Sun Oct 17, 2021 8:49 pm
Has anyone swapped their stock stem for an SL7 item? Savings to be had but I've read conflicting posts about compatibility... I think I need a longer stem anyway so thinking about options and I like the stock aerofly ii bars (otherwise would be looking at Bont RSL VR-C). Stock setup looks clean too.
A few have done it but it's not a perfect match since Venge and Tarmac spacers are shaped differently. You'll find a bit of information here:
viewtopic.php?f=3&t=165143
johnrho
by johnrho
steamroller wrote:
johnrho wrote:
Thu Jan 21, 2021 5:50 am
blind76 wrote:Which bottle cages dor sw venge carbon satin - black?
Rib cage black mat, rib cage black glossy, black elite vico carbon? Something else?
I put Enve cages on mineImage
How did you prop your bike up to get these photos?? :)
Lol I actually don’t know - my LBS who built the bike took the shots for IG. I’ll ask them how they did it as they do it for all their posts
steamroller
by steamroller
Maddie wrote:
Sun Oct 17, 2021 9:14 pm
Thanks Maddie,do you know if anyone has managed to created a 3D printed interface between the venge frame and SL7 stem yet?
moonoi
by moonoi
johnrho wrote:
Probably bought one of these, or made there own version
https://shadowstand.com/
Sent from my SM-F711B using Tapatalk
aintlifegrand
by aintlifegrand
as sacrilegious as it might sound, anyone has any experiences with handlebar bags that would fit aerobar and be small enough not to hit the front wheel ?
ohjinguh9
by ohjinguh9
aintlifegrand wrote:
Fri Nov 05, 2021 9:25 am
https://roadrunnerbags.us/products/burr ... le-bar-bag
i use this, mostly on my gravel/town bikes, but it fits the venge too. They do a larger and smaller version as well.
blind76
by blind76
I have 54 size venge and I'm 179cm with short 82cm inseam and 725mm saddle height.
I have stock 100mm stem and I did bike fit and (pretty good) fitter told me that 100mm is fine and even 90mm would be good/better) but by specialized size guide that should be too small for me...
What stem do you have and do you have any suggestion?
I also have Crux 54 with 100mm stem and maybe feels better...
Before I had tarmac SL5 in size 56 with 100mm stem and the bike was definitly too big.
seaneT1
by seaneT1
I am 1,83m, ride a 54 size Venge and have the saddle at around 75cm and have a 130mm stem with a 42cm bar. Do whatever feels best for you honestly, don't bother with size guides and stuff that much...
BigBoyND
by BigBoyND
Size guides are terribly generic. Ignore it. That's what fits are for, so trust those instead
blind76
by blind76
seaneT1 wrote:
Fri Nov 12, 2021 8:51 pm
So you are 4cm taller than me and almost only in legs and have 3cm bigger stem...
Have you tried it 100mm stem and what is the diff between them?
seaneT1
by seaneT1
blind76 wrote:
Sat Nov 13, 2021 6:35 am
It came with a 100mm stem on, used it like that for about 3 months before going to 130mm, and before changing, I always felt crammed. I couldn't fit my hands and couldn't get lowat all. Also, I couldn't control the bike really well when going downhill with the shorter stem. After the change, everything felt and fit waaaay better.
deepalk
by deepalk
Hi guys just wondering of any one has any experience with thru axles coming slightly undone on the Venge. I recently went out for a ride and noticed my front brakes were rubbing ever so slightly while out of the saddle. Got back home and checked the thru axles both front and rear. They were slighlty loose. I has previously torqued them to 15nm as specified. Probably done over 2000km since the wheels were tightened. Could the grease applied to the shaft and the thread be causing them to unwind slighlty? Would there be any downside to applying to some blue loctite to the thread only?
blind76
by blind76
seaneT1 wrote:
Sat Nov 13, 2021 2:22 pm
Regarding the descending... I'm also "fighting" with descending even on the small wind with those 64s...
I'm thinging about to change to 110mm but that would be probably not enough to feel the difference
andreas
by andreas
Man I'm tempted to try a size 54, I feel I don't get enough weight over the rear wheel when going downhill, and feel like I'm trying to "control the bike" instead of just "being an extension of it". Size 56, 184 cm height, seat at 74.5cm, 120mm stem, 0-offset seat post.
On my gravel bike I'm running a 55 ETT frame with 32mm offset seat post and 120mm stem, and it handles so well comparatively downhill.
Nickldn
by Nickldn
andreas wrote:
Sun Nov 14, 2021 11:13 am
Have you tried a setback seat post?
Your position over the rear wheel should not change much if you downsize the frame, unless you change your fit. In fact if you get a longer stem there is a fair chance you will have less weight over the back.
Giant Propel Advanced SL Red Etap 11s Easton EC90 wheels CeramicSpeed BB Zipp SL70 bars 6.5kg
Vitus ZX1 CRS Campy Chorus 12s Bora WTO 45 disk brake wheels Zipp SL70 bars 7.5kg
SL8 build with Craft CS5060 Wheels in progress
