S-Works Venge 2019
If you are riding Specialized crankset, you need to take the spider/crank arm interface apart and clean it, then reassemble, checking for proper seating. If that doesn't solve it, you need a new spider or crank. If it's Shimano, you need a new crank.
It's S-works crankset.
That play is not that big (but it's visible if you concentrate). Maybe that is even normal.
Can someone else take a look? Just put it into big ring look from above and see if there is a lateral movement between chain and FD.
I want to replace my Aerofly 42cm handlebar with the 40cm version, but I cannot find any shops in europe that stock this model.
I am concidering to go with the Pro Aero Superlight handlebar, but there might other good alternatives to Aerofly.
What handlebar would you recommend?
My Venge Pro ready for the season
No, this is an older colorway derived from Fernando Gaviria's success sprinting at the Giro (winning the Ciclamino Jersey) while riding for Quickstep.
It is the 2019 MY: https://www.specialized.com/de/en/venge ... 97819-1149
Exactly. 2019 Version. Was lucky to find one end of the season last year brand new at a shop. Same layup as with the S-Works
Hi
can you just check while you are riding if you also have that small lateral chainring movement?
https://drive.google.com/file/d/1XDE4YS ... y7q06/view
