Good to know! Can't wait to get out on mine, just waiting for a 0mm offset seatpost.
S-Works Venge 2019
Also the least aero, lol
Just having ordered a frameset I revisited the Specialized web site and didn´t find any info about the stem being included. Which is strange since I´m 100% sure it was mentioned as included a couple of weeks ago.
Any info?
Any info?
Current:
S-Works SL8 RTP (build in progress) | Diverge Comp Carbon
Retired:
S-Works SL7 | S-Works Venge | Ultimate CF SLX Mk IV | Ultimate CF SLX Mk III | S5 | R3 | Cento | ...
Retired:
- alexneumuller
- Contact:
I have ordered frameset as well in Germany, and stem is not included. Am trying to find out if stem can be ordered separately. If not then I’m going For Enve aero stem and aero bar combo
ill principe wrote:Just having ordered a frameset I revisited the Specialized web site and didn´t find any info about the stem being included. Which is strange since I´m 100% sure it was mentioned as included a couple of weeks ago.
Any info?
- alexneumuller
- Contact:
Where did you order yours, as I need one.
You can buy the stem and bar from your local Specialized dealer. If you want to order online, you can find them here:
https://www.cyclestore.co.uk/specialize ... 9-ID_75825
https://www.cyclestore.co.uk/specialize ... 9-ID_75426
- alexneumuller
- Contact:
Perfect. Thank you
lovemyway wrote:You can buy the stem and bar from your local Specialized dealer. If you want to order online, you can find them here:
I picked up my Venge frameset from my LBS in Winnipeg and the stem WAS included... Stems are available seperately as mentioned (I ordered a 12 sepertaly).. I can tell you they do NOT include the rear cover plate or any of the computer mounting hardware.. you get the basic stem and the front cable guide routing for behind the bar...alexneumuller wrote: ↑Fri Nov 30, 2018 8:58 pmI have ordered frameset as well in Germany, and stem is not included. Am trying to find out if stem can be ordered separately. If not then I’m going For Enve aero stem and aero bar combo
Any info?
Better than Trek frames where you need to buy the Seat mast..... re: Emonda
ParisCarbon wrote: ↑Fri Nov 30, 2018 9:25 pm
Everything included in mine..moyboy wrote: ↑Sat Dec 01, 2018 2:28 amBetter than Trek frames where you need to buy the Seat mast..... re: Emonda
Frame, fork, Ceramic Spd BB30 bearing (pulling since Im going Campy..unfortuneately installed from the factory) Stem and applicable fittings, computer mount, seatpost, rails for both saddle rail types,Bats for Aerofly II bars, grommets.. seems there is some kind of mess up with the stem not being included with the frameset... my stem actually came intalled on the bike with all the spacers under it...
Not quite a Venge question but... has anyone the real differences between the S-Works Tarmac and the Tarmac Pro (both 2019)? Aisde from the 10R versus 12R carbon -- what's that in real weight, etc., difference?
Awesome photos! Just ordered this myself, picking it up after the weekend.
Do you have any more photos?
S-Works Venge 2020
S-works Aethos
Specialized Diverge 2021
S-works Aethos
You can order the seat post from a specialized dealer:alexneumuller wrote: ↑Fri Nov 30, 2018 8:59 pmWhere did you order yours, as I need one.
28119-3300 SW VENGE CARBON POST 300MM 0 OFFSET
28119-3310 SW VENGE CARBON POST 390MM 0 OFFSET
2021 Factor Ostro VAM
2021 Factor LS
2018 Trek Speed Concept
2021 Factor LS
