S-Works Venge 2019
Hi,
I finally finished my absolute dream bike.
She weighs a healthy 6.37 kg. The specifications are as follows:
- Specialized S-Works Venge 2019 56 cm
- Shimano R9170 Dura-Ace groupset
- S-Parts titanium bolts for frame and groupse t
- Shimano R9100 Dura-Ace 11-28 cassette
- Sram Red 22 Exogram 172,5mm crank arms with spider
- Stronglight 5-arm 110bcd 50t chainring with Sram red 34t 487g crank with chainrings
- Favero Assioma Uno power meter pedals
- Aliexpress 132mm 61g saddle
- EXS Aerover 380x110 cockpit with EXS 3d printed titanium wahoo+gopro mount
- Supacaz Suave bar tape
- Specialized Aethos expander
- Specialized Aethos front and rear thru axels
- Farsport Hyper 50/58mm 24INT/30EXT rims with carbon spokes on RD270 hubs-1273g with tubeless tape
- Michelin Power cup 25mm (measured 30mm) tyres
- RideNow 24g TPU tubes
- Galfer Wave CLD 160/140mm rotors
- Shimano L05A-TX pads
- Aliexpress 9g bottle cages
- Hylix 140g seatpost
- Moltenspeedwax waxed YBN SLA110 chain
- Aliexpress Mixed direct mount hanger
- eucalyptus
Aliexpress saddle? Thats a Gelu K1 ? They are spanish... high end 400 eur haha
amazing weight! Very light wheels, very very light for 50/58mm!!!
Thank you. Unfortunately, the seller did not comply with my request for no logo on the saddle. It's a wider 132mm version, so it's not a 1:1 copy, but I don't feel too good about it. I think I'll try to remove it somehow...eucalyptus wrote: ↑Mon May 13, 2024 9:29 amAliexpress saddle? Thats a Gelu K1 ? They are spanish... high end 400 eur haha
Beautiful, congrats!wziel wrote:Hi,
Would you please share the link for the saddle and the bottle cages?
Thanks
- eucalyptus
Found it!Fideliojbc wrote: ↑Mon May 13, 2024 10:05 amBeautiful, congrats!wziel wrote:Hi,
Thanks
Search k3 carbon saddle
Store OdinZeus are sell all kind of variations with lightweight saddles.
Like insanely light, 60 grams..
Amazing build with a much higher than usual attention to detail.
You should post it in the Introduce Yourself / Gallery subforum
Some minor recommendations:
for the radar / light mount I can recommend concentric cycling
Weights for my SL6 version:
Also I'd keep an eye on rear shifting quality. Personally I like the more solid ones which are stiffer to resist shifting forces and are not that much heavier. Silca makes a Ti 3D printed one while pilo (europe) and wheelsmanufacturing (USA) make great machined hangers.
- wheelbuilder
Don't share counterfeit links man.eucalyptus wrote:Found it!Fideliojbc wrote: ↑Mon May 13, 2024 10:05 amBeautiful, congrats!wziel wrote:Hi,
Thanks
Thank you for your kind words and recommendation. I was actually thinking about rhinoworkshop's r-works hanger, but I'll consider your recommendation. My Varia mount is not necessarily the stock one I bought it from https://www.ebay.pl/itm/375170663533 and used the stock rubber band which turned out to be lighter.OtterSpace wrote: ↑Mon May 13, 2024 7:33 pm
I bought it from taobao through Pandabuy https://detail.tmall.com/item.htm?id=665989920548 It end up being cheaper than on ebay. But here is ebay seller https://www.ebay.co.uk/itm/29555350536 ... 101224.m-1
Very nice build, I do own a venge as well and was thinking on switching the oe stem/bar combo to EXS Aerover, on yours I do see somekind of spacer between the handlebar and the headset topcap that doesn't sit flush, can you elaborate on that pls, is that the spacer (transition) that exs provide for the venge or something you put yourself?wziel wrote: ↑Mon May 13, 2024 9:19 amHi,
regards
it doesn't sit flash because I don't use the exs transition spacer. The fork steerer tube was cut to a minimum for the OEM stem by the previous owner. The stack on the exs is a bit higher than the OEM, so I decided to "gain" some of the steerer tube by removing the transition spacer. TBH I like a lower position, so this worked for me.AG51 wrote: ↑Tue May 14, 2024 6:05 pm
regards
Ok thanks for the info, at this time I have: oe headset cap,5mm spacer and transition spacer for the -12 stem, I believe the EXS kit might work.wziel wrote: ↑Tue May 14, 2024 10:21 pmit doesn't sit flash because I don't use the exs transition spacer. The fork steerer tube was cut to a minimum for the OEM stem by the previous owner. The stack on the exs is a bit higher than the OEM, so I decided to "gain" some of the steerer tube by removing the transition spacer. TBH I like a lower position, so this worked for me.AG51 wrote: ↑Tue May 14, 2024 6:05 pm
regards
