S-Works Venge 2019
Not directed at just you, but I figured you might know the answer given the number of frames you've built up
I recently moved and my 58cm Venge frame is still on the shipping container for another week or two. Now I'm looking to place the last few orders so that I can build it quickly when it arrives. Since I don't have the frame in hand, I can't take the neccesary measurements.
The build will be with R9200 calipers and 160/140mm rotors.
1. What is the thickness of the frame where the rear caliper fixing bolts C and C2 pass through? Attached is a table of the available lengths. The calipers came with the lengths for 25cm chainstays.
2. For the front which type A bolts do I need? On bike24 there looks to only be two lengths, "standard" and "for R9170." The manual isn't clear on the difference. And do I need to order the snapring separately?
3. What length Di2 wires will I need for a 58cm frame with the battery in the seatpost? Since this is R9200/R8100build, I just need FD-to-battery and RD-to-battery wires. Ideally I would like to minimize the length so there isn't a bunch of uneccesary wire sitting in the frame.
Thanks in advance!
1. it's 25mm, so the bolts already have the correct length
2. I used the ones that came with the front caliper
3. for my 54cm frame I used 500mm and 1000mm. The 500mm for the FD were a bit t short for my taste, so for a 58cm frame I would use 600mm and 1050mm/1100mm.
Looks like the 58 seat tube is 42mm longer than a 54. Chainstay is the same. So in theory I need 42mm more length than you. There doesn't seem to be a 1050 or 1100 available. Only 1000 and then 1200.omikronphi wrote: ↑Fri Apr 15, 2022 7:50 pmFor my 54cm frame I used 500mm and 1000mm. The 500mm for the FD were a bit t short for my taste, so for a 58cm frame I would use 600mm and 1050mm/1100mm.
Do you think 1000 would work comfortably?
1200 or 1400mm on all builds to allow some flexibility taking the bike apart and not losing a short wire inside the frame...
IG: RhinosWorkshop
IG: RhinosWorkshop
- MrCurrieinahurry
- Moderator
Hope you don't get any stones or debris stuck in that tread
Basso Diamante super record EPS 12
BMC slr01 ultegra Di2
Just did it for a laugh, no discs on the wheels as you can see! Reckon it would be doable on fine dry gravel with a little bit of stick on frame protection. Might give it a go. Rear wheel has quite a lot of clearance.MrCurrieinahurry wrote: ↑Wed Apr 20, 2022 9:35 amHope you don't get any stones or debris stuck in that tread
- robbosmans
- Moderator
- Contact:
Going to need a full picture of the bike, the paint looks great!
- MrCurrieinahurry
- Moderator
PhewMrMorrison wrote:Just did it for a laugh, no discs on the wheels as you can see! Reckon it would be doable on fine dry gravel with a little bit of stick on frame protection. Might give it a go. Rear wheel has quite a lot of clearance.MrCurrieinahurry wrote: ↑Wed Apr 20, 2022 9:35 amHope you don't get any stones or debris stuck in that tread
Here you go!! Upgraded to 12 s ultegra since these were taken....robbosmans wrote: ↑Wed Apr 20, 2022 11:00 amGoing to need a full picture of the bike, the paint looks great!
- Contact:
phone doping is the new sock doping!
Eh?
