S-Works Venge 2019
No cover for the seatpost collar like on the Tarmac on any Venge.
All new Roval road wheels are tubeless ready. Just need to get a pair of valves for the Venge Pro as they aren't included with CL wheels.
/jonas l
http://instagram.com/jonaslundb
Quite a few bikes come with it.CrankAddictsRich wrote: ↑Fri Feb 22, 2019 6:56 pmIt amazes me that people are still surprised that a Di2 bike doesn't come with D-Fly... its been out for at least two years and no bike has ever come with one, to my knowledge.
Hi Lukas,
I'm guessing you're referring to the cap that goes behind the stem - your frame should come with two of them: one that allows the steerer tube to go through so you can mess with your position a bit, and one thats closed off for when you're brave enough to cut the steerer tube to length
The computer mount is also part of the frameset, and with it there should be a crazy amount of adapters for Garmin/Wahoo/Polar/whatever computer you have. I don't have it with me right now, but I wouldn't be surprised it if has 10 different ones.
thanks a million!L3X wrote: ↑Mon Feb 25, 2019 11:24 amHi Lukas,
If you bought just a frameset, the stem is not included. If the bike shop ordered you a stem for your frame, it would come separate and would not come with the cap or the computer mount. All those parts are separate when you order a frame only because you can use any stem you want on the Venge.
2021 Factor Ostro VAM
2021 Factor LS
2018 Trek Speed Concept
2021 Factor LS
Where do you live? In Europe the stem + all those accessories are included in the frameset eventhough it's not listed as such if you lookup the frameset on Specialized's site.JeffK wrote: ↑Tue Feb 26, 2019 3:36 pmIf you bought just a frameset, the stem is not included. If the bike shop ordered you a stem for your frame, it would come separate and would not come with the cap or the computer mount. All those parts are separate when you order a frame only because you can use any stem you want on the Venge.
Just recieved my 52cm 2019 Venge in the USA and it came complete with 90mm stem, spacers, frame hardware, and computer mount, complete with multiple inserts. I ordered a 110cm stem, so if anyone needs a 90cm, I have one available.JeffK wrote: ↑Tue Feb 26, 2019 3:36 pmIf you bought just a frameset, the stem is not included. If the bike shop ordered you a stem for your frame, it would come separate and would not come with the cap or the computer mount. All those parts are separate when you order a frame only because you can use any stem you want on the Venge.
GP5KTL 25mm on CLX50 was doable but pretty tight. Had to use tire levers and a lot of force. Floor pump was enough to seat the tire and that was without any sealant using only the original tape. I am waiting for Corsa TL reviews about rolling resistance (and puncture resistant/comfort) before buying another GP5K.andreas wrote:Anyone got experience with mounting the GP5000TL on the Roval CL/CLX wheelset? Got them incoming, but considering cancelling for the Vittoria Corsa TL instead.
