Thanks! I've anyway just discovered that the frameset isn't compatible with mechanical groupsets, so there goes my financial ability to build one.
S-Works Venge 2019
The Vias clip-ons will work with a new clamp underneath the stem I heard from Specialized yesterday.
/jonas l
http://instagram.com/jonaslundb
My build is now almost ready. Somehow did not get the brakes to work and the second gear (12 teeth) a far away from smooth although all other gears are shinfting fine.
I will now let my LBS take a look as they also are taking care of cutting the steerer tube for me
Hope my spec list and weights are useful to someone. Let me know if i should share some more info.
The bike as shown on the photo comes in at 7.85 kg
Legs speak louder than words
2011 S-Works Tarmac SL3 (7.03 kg)
2014 Specialized Enduro Expert (13.04 kg)
2019 S-Works Venge SaganCollection (7.78kg)
you list is a bit confusing as some "included in framset" items have weight figures and some don't. the list add up 7,734g...
"included in" means that this was not purchased separately, if i stated a weight this is the actual weight the component has.
The sum is less than the total weight because of grease and maybe because of weighing with 2 different scales.
i weighted each part with my kitchen scales and the whole bike with my park tool scales.
Just to clarify: the frame weight as i measured it includes the BB and headset baerings
RedOne, I think your weight itemization is awesome. Thank you!
Cannondale Supersixevo 4 (7.05 kg)
Retired: Chapter2, Tarmac SWorks SL6, Orbea, Dogma F8\F10, LOW, Wilier, Ridley Noah, Cervelo R3\R5\S2\Aspero, Time Fluidity, Lapierre Pulsium, Cyfac, Felt, Klein, Cannondale pre-CAAD aluminum
I compared a S-Works Venge in size 56 in black standard colour with the Sagan colour. 7,22kg for the black, 7,48kg for Sagan. both completely stock including the garmin mount. So 260g But a really awesome colour
/jonas l
I like it , if for no other reason than it is different from the black we are all familiar with. I think Specialized sponsored triathlete Flora Duffy is on that color: https://www.instagram.com/p/BmwbO5jH8Cx ... hare_sheet
I looooove the grey. Best bike color spesh has made in a while.
Do these include the pedals and water bottle cages? I thought the new Venge was 7.1kg ready to ride? Whilst I like it (a lot), it is still heavy then...?
Check out Instagram. Several photos of the grey built up. Looks really good IMO.
