S-Works Venge 2019
I think I’ve seen that at least once on Youtube, to be honest it did not even look that bad.
Edit: here is the link, you can see it at 20:00
https://youtu.be/kbpqVsJ8bxQ
Thanks. I think it looks good. I know some people might think it's odd to have a full disc on a road bike, but with the extensions it's not far off being a decent TT bike IMO. My segments are pretty even when I compare P2 with my Venge.
I found this pic of Remco Evenepoel as well https://www.instagram.com/p/CCXtpEdHdys/
I am looking for a frame and there is nothing out there. Size 58
Enviado desde mi iPhone utilizando Tapatalk
Yes.
PM me.I might have one for you depending on size you need
Hi everyone. just wondering if anyone uses c-bear ceramic bb or jockey wheels? My venge needs a new bb (quite surprised the ceramic speed bb that it was built with didn't last longer!) So thinking of c-bear over c-speed.
Also can anyone tell me which of the c-bear bb's are specific to a venge with sram axs etap?
thank you.
thank you.
C-Bear BB-30-DUB-R is the one you want.
Their OCM full ceramic pulley wheels are also great (have both on my Allez).
IG: RhinosWorkshop
IG: RhinosWorkshop
Hi guys, I am thinking about buying a used Venge Pro. The bike is in decent condition but I am wondering if there's anything I should consider wrt sourcing parts if I crash or something since this model is discontinued. Thank you.
2019 Giant TCR Advanced Pro 0 Disc
I know this is a late response. On certain chainrings and cranks, there is a pin that screws into the big ring and I think keeps the chain from dropping between the crank arm and the ring. Mine was actually touching the crank arm and pushing on it enough to deflect the ring. I unscrewed it and ground a mm or so off so it no longer touched. Solved the wavy ring issue.
QQ, i have the 2020 Venge Pro with the power saddle with titanium rails. Thinking of replacing the saddle to mirror. Will i need to change the seat clamp?
If yes, is this the right part? https://www.specialized.com/us/en/anodi ... =2812-9050
Thanks
Thanks
