S-Works Venge 2019
IG: RhinosWorkshop
IG: RhinosWorkshop
Soon to have 6.7s on it...
Size 54.
Size 54.
IG: RhinosWorkshop
IG: RhinosWorkshop
Anything 11 speed works with R9200.
43.5 vs 44.5 vs 45mm chainline makes no difference in the real world.
Always had great experiences with Rotor cranksets.
IG: RhinosWorkshop
IG: RhinosWorkshop
What did you use to mount them there?riochang wrote: ↑Fri Apr 22, 2022 1:27 pmJust installed R9270 on my venge and wanted to try out the new climbing shifters.
I literally struggled for maybe 30 mins thinking whether I should fix these shifters under the handlebar, or under the cable bats, or stick to the side of stem, or somewhere else.
And this is what I have done, first ride today and the position felt great, super easy to reach and shift while hands on the tops.
What you guys think? neat or a bit messy? my cockpit kinda looks like a scorpion...
What bolts are those? Love the oil look.
Road // 2023 S-Works Tarmac SL8 | Shimano Dura-Ace Di2 | Roval Rapide CLX
Gravel // 2023 Specialized Crux Pro | SRAM Force AXS | Roval Terra CL
Retired // 2022 S-Works Shiv TT // 2021 S-Works Tarmac SL7 // 2019 Specialized Allez Sprint Red Hook
Thanks for sharing.riochang wrote: ↑Fri Apr 22, 2022 1:27 pmJust installed R9270 on my venge and wanted to try out the new climbing shifters.
I really like this setup.
- eucalyptus
Looking at this makes me wonder why they released the Tarmac SL7 instead of the Venge, because the Venge looks faster and actually look so much better in the front with the aeroshape form... Weight? You just proved that is not a significant reason as yours pictured are way below 7kg....
just some random Ti bolts from local shops.Ritsuke wrote: ↑Sun Jun 19, 2022 8:21 pmWhat did you use to mount them there?riochang wrote: ↑Fri Apr 22, 2022 1:27 pmJust installed R9270 on my venge and wanted to try out the new climbing shifters.
Mounting brackets for standard 31.8mm diameter handlebar and zip ties are supplied in the shifters package, i simply use these.
