Darimo Carbon components, when Spain beats Germany
Jimmyrn85
by Jimmyrn85
Hi guys, I have a 25.4mm Darimo seatpost for my 2016 Supersix, what is the best way to securely mount my Di2 battery in this seatpost please? Cable tie around bubble wrap squashed in?
Klaster_1
by Klaster_1
Jimmyrn85 wrote:
Wed May 26, 2021 10:52 am
I just wrapped the battery in a couple of dense foam rings and plugged it into the seatpost.
C36
by C36
Jimmyrn85 wrote:Hi guys, I have a 25.4mm Darimo seatpost for my 2016 Supersix, what is the best way to securely mount my Di2 battery in this seatpost please? Cable tie around bubble wrap squashed in?
I use https://eu.ritcheylogic.com/eu_en/bike/ ... bber-mount
Cost 6€ and works (to be complete I only insert it 2cm, then friction is too high so I could trim it cutting half).
tskubi
by tskubi
you see the same seat post as me?
T2 15mm set back seat post there.... no logo of course.
Image202857374_10159925422934131_6051833426474462602_n by Thomas Skubiszewski, sur Flickr
Enjoy your time under the sun.. and when its cold and dark don't worry too much, the world will keep spinning and your time in the sun will come again.
Aryeh
by Aryeh
What torque do you guys run with the T1 loop? I recently got the seatpost for my R5 and at 3nm it came loose after a few rides.
jlok
by jlok
Aryeh wrote:
Fri Jun 25, 2021 2:53 am
Yeah, 3Nm but I used a drop of loctite 242 on both screws.
exctasy
by exctasy
Finally decided to purchase darimo products.
Just received my ellipse handlebar however I've got this nick / indentation. Totally unexpected for a premium product.
Darimo told me it's safe to ride.
What are your thoughts guys?
wheelsONfire
by wheelsONfire
exctasy wrote:
Fri Jul 23, 2021 4:14 am
It's probably as he says, question is if you accept a new bar with this? I wouldn't!
Bikes:
viewtopic.php?f=10&t=156137
Open *UP* (2016.04.14)
Ex bike; Vial EVO D
xsnailx
by xsnailx
glossy ud finish of darimo products has its quirks unfortunately - mine have simillar inperfections but i live with that as it is a penalty that you pay for the low weight. It is still better that a flaky glossy coat on thm clavicula se that started to fall off after approx 1kkm. For me it is a lesson learned if you want lowest weight carbon parts - go for a matte ones ;-)
KCookie
by KCookie
exctasy wrote:Finally decided to purchase darimo products.
If the bar tape covers the imperfection i wouldn't worry about it, but if not i would send them back as it would drive me mad looking at it every time I went for a ride.
Sent from my SM-G986B using Tapatalk
Prawn
by Prawn
tskubi wrote:
Wed Jun 23, 2021 9:33 am
Well spotted! Weight still matters... need something to offset the added weigh of the SRM crankset and disc brakes
