Darimo Carbon components, when Spain beats Germany
liam7020
by liam7020
Thinking of upgrading my 3T Ergonova bars to the Darimo. My 3T bars are 42cm but, obviously as we know, they are flared and only measure 40cm at the hoods where I do most of my riding so I'll probably order 40cm in the Darimo bars. I've read through the Darimo literature and haven't seen any mention that the Eclipse bars are flared so I'm assuming they're not.
The Darimo bars have 5mm more drop than the 3Ts but with the flare a little trig suggests that it's actually nearer to 2-3mm which is irrelevant. At nearly 50g lighter and a reasonable price it seems like a goer!!
Tarmac SL6 & Campag Record EPS https://weightweenies.starbike.com/foru ... 0&t=153968
Klaster_1
by Klaster_1
liam7020 wrote:
Sat Feb 02, 2019 11:14 am
The bars are not flared.
Wookski
by Wookski
PokojniToza wrote:
Fri Feb 01, 2019 10:55 pm
To avoid making yet another thread about Darimo - anybody here to give (or point me in the right direction) a long-term review of the setback seatpost?
I have been running the setback post on my Cherubim since October last year. Weight came in at 83.6g and finish was in line with older gen McFK- “agricultural.” I broke a Berk saddle in the first week of using the post but it was a round rail Berk and they seem to break just by breathing on them. Berk replaced with oval rail and has been fine since. The post slips very easily compared to the ENVE and Neil Pryde I’ve used in the same frame, I think it may be slightly narrower in diameter. I have since doubled the amount of carbogrip and slightly increased the clamp torque which has solved the problem.
Comfort and ride quality seem the same as any other seatpost in this frame. It’s a steel bike and I ride tubular wheels: ax, bora or lightweight. The bike already has a beautiful ride quality so the impact of the post is negligible.
The post is very impressive from a weight perspective and i’d probably buy it again. Out of all the setback posts on the market it definitely looks the best.
PokojniToza
by PokojniToza
Thank you.
liam7020
by liam7020
Klaster_1 wrote:
Sat Feb 02, 2019 11:27 am
e]
Cheers for that confirmation.
TimothyLoota
by TimothyLoota
Thats a bit crap ... Ive been using my carbon Specilized Roubaix in a trainer for months
Thanks for sharing tho.
wheelsONfire
by wheelsONfire
Off topic, but i just found these sheets for Ulna
Bikes:
Open *UP* (2016.04.14)
NiFTY
by NiFTY
Can confirm. Ulna are stiff. I have ergonova team as well and they feel stiffer,
Wookski
by Wookski
NiFTY wrote:
Mon Feb 04, 2019 11:38 am
The only bar more flexi than ergonova team is the ergonova LTD :noidea:
RyanH
by RyanH
I'm happy with the Ernovas/Ergonovas other than the mildly retarded side profile shape. Otoh, it probably helps that I'm running them in size 38.
pdlpsher1
by pdlpsher1
RyanH wrote:
Mon Feb 04, 2019 4:04 pm
Ryan,
Does your bar measure 36cm C-T-C at the hoods and 38cm C-T-C at the drops?
I went on 3T's website and on the Superergo (Ergonova/Ernova's replacement I think) the smallest bar listed has 38cm C-T-C at the hoods and 40cm C-T-C at the drops. For some odd reason 3T is now using 'W1' for bar sizing as THM is using 'W2' for bar sizing. And 3T owns THM. Weird.
wheelsONfire
by wheelsONfire
I agree with above, it's so weird that THM (ex) 42 bar is actually 42 cm C-C in the drop handle end and 40.4 cm C-C at the hoods.
This would be a 40 size bar if it was 3T.
Bikes:
pdlpsher1
by pdlpsher1
I have a 3T Ergonova with a printed size of 40cm. The bar measures 38.xcm at the hoods and 40cm in the drops. So in the past 3T was using 'W2' for bar sizing. That's why I'm asking Ryan if his bar is 38cm at the hoods or at the drops. Don't know when and why 3T changed the bar sizing from 'W2' to 'W1'.
KarlC
by KarlC
pdlpsher1 wrote:
Mon Feb 04, 2019 5:36 pm
Ryan,
I have the 3T Ergonova LTD Bars in 38 and yes they measure 36cm C-T-C at the hoods and 38cm C-T-C at the drops. Here they are striped down, they could use a bit more sanding, I left the grit for the shifters, not sure its really needed tho
C64 My Sixty 4 SR EPS 12
pdlpsher1
by pdlpsher1
Yeah I think 3T used to carry the 38cm but now their latest bars in a 38cm are really comparable to the older bars in 40cm. Not sure why you can't get a true 38cm anymore, even on the THM Ulna.
