Darimo Carbon components, when Spain beats Germany
Maybe they now provide longer Dyneema cords?
Which barrel, rear or the front? Did you try to unscrew the front barrel to the max?
Both barrels loosened off to the max then tried to bring the Dyneema down and over the front barrel and it just wouldn't reach.
Never had a problem with the round Berk saddle.
Sent from my SM-G986B using Tapatalk
Has anyone else tried the available adaptor from Darimo for fixing a front light via the GoPro adaptor? I have a Varia 800 and would love to mount it, Darimo said the weight/stress is fine but real world users would appease the mind a little! Last thing I want to see is either my Garmin stuff or the mount not attached to the bike
My Darimo mount broke sending both my Garmin edge 530 and small Bontrager light to the pavement. They sent a free replacement but I have since switched to the Alpitude mount.
Both Garmin and light are on the smaller side...its not like you had a Garmin Edge 1030 and Niterider light that's both heavy.
I may need to put a tether on my Karoo2 just in case (and with no light underneath).
- Factor Ostro VAM Disc
- Factor LS Disc
- Specialized Aethos Disc
- Sturdy Ti Allroad Disc
- Guru Praemio R Disc
- Factor LS Disc
Ive had bad luck with lightweight mounts and so have a number of friends of mine.. I dont want to see my 1030 doing cartwheels.
2024 BMC TeamMachine R
2018 BMC TImeMachine Road
2002 Moots Compact-SL
2023 Pivot E-Vault
2023 Pivot E-Vault
Good luck with the Alpitude holder. Mine snapped this morning sending my 1030Plus and Ion RT tumbling across the tarmac. Two months worth of riding for over one hundred euros. Total weight of 149.5 grams, so well under the manufacturer's stated 250g limit.
Does anyone know of a sturdier mount for Darimo stems? Maybe aluminum? I love the clean package leaving my bars uncluttered.
- Moderator
Anyone struggled getting a darimo bar on a darimo stem? The YouTube video didn't help
Allegra- Steel Lugs TBC
Aurelia- Stainless All Road 8.5kg
Bertha- TT 9.8kg
Perdita- Ti Turbo bike 8kg
Serenity- Ti Gravel 9.5kg/8.9kg
Verity- Ti Aero 8.2kg
Alya- Ti Climbing TBC
Bertha- TT 9.8kg
Agree this was a bit scary. Did you use a hex key as recommended in the video? What went wrong, I guess the fit was still too tight?CustomMetal wrote: ↑Fri Aug 27, 2021 7:34 amAnyone struggled getting a darimo bar on a darimo stem? The YouTube video didn't help
- Moderator
Yeap, have a hex key at 8mm in the gap and still can't get past the drops
Bertha- TT 9.8kg
Bertha- TT 9.8kg
