cracked aluminum frame
spud
by spud
I've attached a pic of an old standby aluminum frame that got a crack on the seat lug. My view is that I should cut the lug off, drill a new stress releaver hole at the back of the seattube, slot the tube and use a collar. I suppose it might be possible to weld the lug/rub shut, but I think this will entail higher expense, along with a possibility of the crack reopening later.
Any alternative ideas?
flying
by flying
Your method sounds like a good option & will likely be fine
I guess the only question is that the remaining section is fairly short & close to a big weld
so might not flex enough when clamped to tighten. But if you slot as you say I imagine it would.
NiFTY
by NiFTY
I would do as you propose.
alcatraz
by alcatraz
What's the outer diameter of that seat tube?
/a
mattr
by mattr
NiFTY wrote:
Mon May 28, 2018 4:05 am
I have done as you propose. ;)
Cleaning up the top of the new seat tube was probably the most time consuming job.
Have seen it done several times, Even seen a sculpted clamp to clear a weld.......
alcatraz
by alcatraz
Before cutting I'd probably try to dremel away the ears and clean up the seat tube. Then I'd try to fit a clamp over it. If there is a big tube piece missing I'd try to fit something there.
The reasons for this are:
1. weak clamping force near a huge weld
2. hard to find clamps that are the right diameter and can provide enough clamping force to hold the seat tube
3. it looks better (personal) when the clamp isn't slammed
Bridgeman
by Bridgeman
alcatraz wrote:
Mon May 28, 2018 3:58 pm
Great advice. I would also add that it would be wise to lengthen the relief slot and include a new hole at the end of it. I've experienced a similar issue and this slot length increasement solved the cracking problem so well that the manufacturer adopted the modification.
