Rca WW Build.
tabl10s
by tabl10s
Delivered the KMX SL11 to the LBS as they didn't carry the brand and a salesman brought the bike out to weigh it. W/O the chain, Jagwire brake housing, Look Ti Keo's and 1.8 Lizardskin, it tips the scales at 10.16lbs(4.808kg).
I'm too old to mess with tubular's and was wondering how much I can save with top caps, expanders, chainring bolts and such.
2016 Orbea Orca OMR:
15.0lbs/6.804kg.
2013 Wilier Zero.7:
13.02lbs/5.906kg.
2016 Rca:
11.07lbs/5.048kg.
2015 Pinarello F8(build in-process).
NiFTY
by NiFTY
Probably need a build list
tabl10s
by tabl10s
Deleted.
15.0lbs/6.804kg.
2013 Wilier Zero.7:
13.02lbs/5.906kg.
2016 Rca:
11.07lbs/5.048kg.
alcatraz
by alcatraz
Chainring bolts are around 7gr for 5 light ones.
Expander can be 6-10gr but if you need to preload your headset a lot then they won't work very well.
A PYC SP1101 chain is around 10-20gr lighter than a kmc x11sl.
Top cap you can leave off until you need to adjust your bars/headset. If you want to leave it in then 3gr with an alloy or carbon bolt should be possible.
Low hanging fruit is handlebars/seatpost/inner tubes/skewers/cassette/tires/rimtape/brakes.
tabl10s
by tabl10s
Not sure what preloading is. How does it affect the ride?
15.0lbs/6.804kg.
2013 Wilier Zero.7:
13.02lbs/5.906kg.
2016 Rca:
11.07lbs/5.048kg.
tabl10s
by tabl10s
alcatraz wrote:
Sun May 27, 2018 8:12 am
I thought KMC was the best?
15.0lbs/6.804kg.
2013 Wilier Zero.7:
13.02lbs/5.906kg.
2016 Rca:
11.07lbs/5.048kg.
alcatraz
by alcatraz
Kmc might shift better but your result may vary depending on how well it mates with your cassette/chainrings.
I was just talking from a lightweight point of view, still keeping in mind durability and price. There are titanium chains out there for 100+usd if you like to save another 20gr but they must wear out faster. Might be fine if you're pushing low watts, high cadence and don't weigh a ton.
With preloading I mean how much you need to torque that top cap bolt after you've fiddled around with the stem (as in, made adjustments to your fit). Some bikes need to torque that bolt more than other bikes. Depends on how well the bearings fit in their spaces and how well everything is aligned, is my guess. If you have a precision made frame you probably won't need much and can get away with a small compression plug (expander).
tabl10s
by tabl10s
alcatraz wrote:
Sun May 27, 2018 4:19 pm
Sounds like a professional is needed.
15.0lbs/6.804kg.
2013 Wilier Zero.7:
13.02lbs/5.906kg.
2016 Rca:
11.07lbs/5.048kg.
4ibanez
by 4ibanez
It's actually really easy, and a skill you should learn. Eventually you'll probably have a headset come loose, or decide to swap bearings out.
Take off the top cap, loosen off the expander you have in place, but not fully. Undo stem bolts, but leave the stem in place. Remove expander if using a WW one. Keep a bit of wire handy in case you lose the expander down the steerer. They like to fall in, but they never seem to slide out as easily!
To adjust the headset: Just iteratively tighten your heavy OEM expander/top cap/steel bolt in the steerer... Be aware the expander needs to cover the area between your stem bolts, so check it's in the right position first. Then tighten it up with an allen key. Between wrenching, hold on your front brake and rock forward and back on the bars. It'll feel loose and rattle around a bit. Keep tightening til this stops (compare to another bike to familiarise yourself with a correctly adjusted headset). Too tight and your steering will drag. Once it's pre loaded correctly, you're ok to put your light top cap on in place of the heavy one - just nip it snug.
Or if you're installing a light expander e.g. Extralite/EE, do all of the above with a spare/OEM expander/top cap/bolt up til the last step. Then take out the heavy expander and replace with the WW one (your headset should still be pre-loaded). Tighten it a touch before putting it in the steerer so you have to push it in (so it doesn't fall in), and put it in the correct place. Install to the mfg specified torque spec being careful not to push further into the steerer, then throw on a top cap and bolt (the lighter the better) and nip tight.
Remember to tighten your stem back up! Should take about 5 mins - watch a youtube video too if that help some of the above make more sense.
tabl10s
by tabl10s
Extralite vs EE, ... what's your favorite?
15.0lbs/6.804kg.
2013 Wilier Zero.7:
13.02lbs/5.906kg.
2016 Rca:
11.07lbs/5.048kg.
alcatraz
by alcatraz
Remember that the ultralight expanders can not be torqued very high. It'd be good to use a calibrated torque wrench. I'm always afraid to break my light compression plugs.
4ibanez
by 4ibanez
I've heard good things about the EE one, and the expander is about 0.5g lighter than Extralite's. But it's quite a bit more expensive and comes with a disproportionately heavy cap and bolt not befitting the world's lightest expander. (Extralite doesn't come with a cap and bolt)
You wouldn't use EE's cap and bolt if that 0.5g difference was important to you - there's loads of lighter options. So on that basis I refuse to pay the premium for parts I won't use, and would go Extralite.
You could buy the Hypercap and the Ultrastar for around the same price as the EE, and you'd have a lighter setup. Or search hard and you could find even lighter top caps, and choose an M6 nylon or carbon bolt if you like.
4ibanez
by 4ibanez
alcatraz wrote:
Mon May 28, 2018 5:35 am
My Ultrastar has a max torque value of 8nm (which I think is quite high). My stem's max torque is maybe 6nm on the steerer, but I torque both a bit less than the max anyway. Never had any concerns about it.
alcatraz
by alcatraz
4ibanez wrote:
Mon May 28, 2018 9:20 am
Ok cool. I'll try to torque mine at 8nm aswell. Although I don't have an ultrastar. It's similarly looking and alloy.
NiFTY
by NiFTY
I also have the extralite hypercap combo. Under 9grams. on 2 bikes. Nil issues. I torque with a normal topcap though and switch back to hypercap after its preloaded
