Pinarello F10 sizing help
wszs91
by wszs91
I’m in the process of upgrading my current bike, cannondale SuperSix evo 54cm, To a Pinarello F10. I have read a lot about Pinarello sizing but I’m a bit confused about it. My height is 5’8.5” and inseam 33”. Current saddle height is 75.5cm, using a 100mm stem, 10cm saddle to handlebar drop and I feel good on the cannondale, I’m thinking about getting a 51.5 Pinarello F10 with a 110-120mm stem or a 53cm with same 100mm stem.
I want to listen some experts opinions before I make the purchase.
Thanks in advance
tabl10s
by tabl10s
I had an F8 thread along these lines with the owner of Glory Cycles responding. Drop him a message/email.
2016 Orbea Orca OMR: 15.0lbs/6.804kg...😐 | 2016 Rca: 11.07lbs/5.048kg...😭 | 2015 Pinarello F8: 13.04lbs/5.915kg...😩 | 2018 S-Works SL6: 12.04/5.625kg... 😥
Bridgeman
by Bridgeman
I'm 6"3" and ride a 58 Felt F1. I had an opportunity to spend a few months on a Dogma F10, size 55. While it was clearly too small, if this was the only size offered I would have taken it in a heartbeat.
I was told by the disributor to go one size smaller than my current bike, so I purchased an F10, size 56. Been on it for a 3 or 4 months now. Complete perfection.
TonyM
by TonyM
I am 5’7” and have a 50cm F10 with a 110mm stem -8 deg. and no spacers. It is quite racy in terms of position but this is what I wanted.
As Pinarello has many available sizes you will certainly have the choice between 2 sizes (or maybe even 3). Take the one which is most appropriate for your riding style and fitness level. For example a smaller frame in order to get lower and have a better aero position if this is what you want and can ride.
wszs91
by wszs91
Thanks for all your replies, i think ill get it size 51.5 and use a 110-120mm with no spacers under stem, hopefully it fits well
ParisCarbon
by ParisCarbon
Id email a few places and get some opinions... it would suck to drop that amount of $ to find the size is wrong.. I made that mistake going from a Prince SL Aluminum to a Paris Carbon way back in 2005.. got the same size and the thing was HUGE... racycles sells Pinarello.. before I got my Tarmac I was looking at an F10.. was thinking going smaller size with 56, but all the shops I talked with said def 57.5
TonyM
by TonyM
Yes definitely check first the fitting depending on the frame size!
Before I bought my F10 I went to the LBS and mimic the different sizes on a Retül bike together with different stem length etc....in order to be 100% sure to have the right size. Even if I am biking between 10.000 km and 15.000 km per year in the last 30 years and have therefore quite a long experience with bikes, the theory only with calculating the stack and reach doesn’t work 100%...
There is indeed no point to have a nice frame if it just fits 90%...and you can only find the right size if you try the different sizes (except if the differences in sizes are huge. But Pinarello offers a large selection of sizes and that will be stupid not to take advantage of it).
And comparing to the size of another frame is usually worthless as the stack, reach, seat tube angle etc...are usually different etc...
syplam
by syplam
are you using di2 for your f10? I am trying to order di2 for my 53 but I am not sure what length I should order for your ewire. Does anyone have any idea?
Sent from my SM-G9650 using Tapatalk
fogman
by fogman
I ride a 51.5 cm Pinarello F10. I am 5’8.5” with a saddle height of 73.3 cm, 110 mm stem, and a saddle-handlebar drop of 8.5 cm. I have 1.5 cm spacers under the stem.
It's all downhill from here, except for the uphills.
wheelsONfire
by wheelsONfire
TonyM wrote:
Sun May 27, 2018 11:56 pm
What do you find lacking going for stack and reach as for best size?
I am curious, that's why i ask.
I was told to go for size 55 from my dealer. I am 182.5cm.
Bikes:
viewtopic.php?f=10&t=156137
Open *UP* (2016.04.14)
Ex bike; Vial EVO D
TonyM
by TonyM
What I meant is that when buying a new bike/ frame it is always a good idea to check if a size smaller or larger would be better. Your fitness/ flexibility may have changed. The new frame may offer a larger variety of size than the current frame. Etc...A text ride with the different sizes would of course be the best option. I personally used a Retül bike to mimic the different sizes together with different stem length etc...
wheelsONfire
by wheelsONfire
I was about to mimic Open UP and Ax Vial EVO.
Only thing same same, is Ergon seatpost and ISM PN 3.1 and 3.0 saddles.
Saddle height is not same, perhaps due to stack of pedals and shoes.
Distance saddle to BB, BB to handlebar is different.
Both still feels spot on and strangely, not different!?
UP uses Lauf fork, in thery this route frame 4mm backwards and shorten reach 4mm.
Vial Evo should be 12mm longer in reach, use same length stem on both bikes.
Handlebar specs, is 10mm longer for Vial EVO compared to UP.
In theory, this is strange and should feel very off!
Anyway, that is why i told you i was curious of your findings.
Bikes:
Ex bike; Vial EVO D
