Riders on disc brakes. How often do you lock up your rear wheel?
sychen
by sychen
Went to Disc recently and have had an emergency stop at the same place i've done the same on the old bike.
Steep hill down to a roundabout where cars sometimes turn without indicating .. probably should slow down more as i've had a few e-stops here.
Old bike would lockup quickly and i would as i have often done, skidded to a stop but under control as a long time mtber have no issues.
Disc bike in the same situation only skid very slightly at the end but had full control the whole time with room to spare.
Frankly I was surpised how much more modulation I had in the same situation. I knew from many tests how much more modulated power I had but only in an emergency did I see how well it can be used.
spud
by spud
assuming noth brake systems are in good condition, disc brakes are less likely to lock due to two things:
1) less friction/hysteris in the systeme - cable friction vs lack of fluid friction
2) even a great rim set up can have a very minor variation in braking force on different parts of the rim - the sticky point can lock when the rear tire is very light on the ground due to weight transfer
I've never locked my rear disc brake unless it was on purpose
dricked
by dricked
All the time. Skids are cool!
superdx
by superdx
Never, not even when I crashed
jfranci3
by jfranci3
Recently switched frames with my road tires / CX frame to same tires / road frame. The differences in the frames are slight with the same fit - 20mm seat stays and steering trail at the opposite ends of the spectrum. Also went from TRP Hy/Rd (cable to hydro) to Sram Force HRD. Same tires/wheels/160mm discs front and rear. I need to got 140mm on the rear with the proper hydro discs and the road frame. They just lock up so easily.
TobinHatesYou
by TobinHatesYou
Going to a smaller rotor will just keep on masking the real problem in your braking technique. Your rear brake is for slowing down, trail braking after entering a corner slightly too hot for example. It Is something you always apply in a controlled progressive manner. If your body can’t feel the additional braking power working and where the limit of traction is, that’s on you. How did you survive with rim brakes, which have worse modulation?
CEVelo
by CEVelo
Whenever I need to drift around a corner...
Modulation is far superior on disc breaks vs. rim, so the risk of locking up the rear is reduced with a good disc system.
Theologian
by Theologian
I've always ridden with disc brakes, first mechanical and now hydraulic, never lock out the rear wheel. But then again, I've never had to "panic brake." As other have said, well designed levers, calipers and pads have great modulation.
MikeD
by MikeD
In my opinion, the more powerful the brake the more likely it is to lock it up. Modulation goes out the window in a panic situation when you're just grabbing brake without thinking. On my mountain bike, I have to squeeze the lever super hard to lock the brake so it almost never locks up. That doesn't mean I'm not going to work on improving the braking power of this brake though.
Theologian
by Theologian
So what's next in bike tech? Anti-lock hydraulic disc brakes?
Theologian
by Theologian
Growing up here in the Northeast, we all had to learn how to "pump" your car brakes in the winter before ABS became standard on cars. In fact, we learned to turn "into" the direction the car is sliding (against intuition) to gain traction should the wheels locked up on snow or ice. I don't think I've ever done that on a bike, the window for reaction is really small. I wonder if ABS would work on bike.
Jugi
by Jugi
TobinHatesYou wrote:
Mon Sep 10, 2018 5:27 am
I wouldn’t call that a flaw in technique. At least for me, the easiest braking system to use is the one which will provide optimal stopping power when a similar amount of pressure is applied to both levers. Intuitive braking in a straight line comes first, finesse in trail braking etc. is achieved when the system works logically.
MoPho
by MoPho
Theologian wrote:
Mon Sep 10, 2018 4:42 pm
Also grew up in the Northeast and learned to pump the brakes. I have similarly pumped the [rear] brake many a time on my road bike when having to make hard stops, particulalry when I was using rim brakes. Can't recall having to do it since going to disc.
Usually if you've locked the front wheel, you've already gone down LOL
dvq
by dvq
Works _really_ well on motorcycles.
dvq
by dvq
MoPho wrote:
Mon Sep 10, 2018 6:37 pm
I think that's one of the things I see that ABS on motorcycles does well -- allows you to retain the ability to stay upright as well as stopping in a shorter distance. Normally you'd just lock the front wheel and fall over as the bike falls over.
https://www.youtube.com/watch?v=dJ_UkAFW6cA
