Garmin EDGE mount for Bontrager XXX integrated bars
toutenhoofd
by toutenhoofd
I’m wondering if anyone knows where to find a Garmin mount like the one in this image:
I don’t need the bars, I already have a set. But I’m having a really hard time finding a mount like that one. I know about Trek/Bontrager’s Blendr solution but I much prefer the simplicity of this one.
Thanks
Nico
www.cyclingtechnology.com
(NOTE: This poster owns a retail business selling weight conscious bike related products.)
alcatraz
by alcatraz
I tried a mount out of carbon that is a bit smaller than the one pictured. (china noname, maybe 8cm long)
It broke at the mount on the first ride. I had put rubber around the bolt to absorb some vibrations. I cut some pvc "washers" from a pvc tube I had lying around.
Seeing as this pictured one is much longer and only held by one bolt, you will probably have a problem going over bumps.
For best luck with a computer over 50gr I think you should look for a short arm version. Going weight weenie might be a mistake. It needs to be beefy around the bolt because that's where it will snap.
NiFTY
by NiFTY
Agreed. That mount looks too skinny to work well. I made my own mount out of carbon plate ( thicker than that) and had to beef it up as it vibrated on rough roads.
TobinHatesYou
by TobinHatesYou
My issue with Blendr so far is that the GoPro mounting system doesn’t provide enough clamp force for something with the leverage of an Edge 1030. My 1030 bounces and flexes the long-low mount that I made, rotating it in the GoPro mount. Torquing it down more just breaks the plastic. A knurled interface would fix this.
Konsi
by Konsi
TobinHatesYou wrote:
Sun May 27, 2018 2:36 am
Hello,
Does this mean that all the mounts for the Blendr XXX system are compatible with other GoPro mounts, too, not only with the Bontrager base?
FIJIGabe
by FIJIGabe
I'm not entirely sure about your question, but I'll try to answer it (I have two versions - one on my Madone, one on my Emonda). What the Blendr mount is, is a GoPro type mount that is "integrated" to the bars. On my Madone, it's secured by a fixing bolt under the bars. On my Emonda, it's the 2-mount system for the Pro stems. Either way, the way the interface works is by attaching whatever accessory mount you want to use with a GoPro-style system (three tabs held by a 4mm allen screw).
Here's a photo of the standard mount:
Emonda SLR https://bit.ly/2UK5FP8
Crockett, Madone 5, Cobia. I own a lot of Treks.
Dan Gerous
by Dan Gerous
I had the same problem of having one tilt down over time during each ride... I put some carbon assembly paste between the two mating parts, it never moved again! :thumbup:
TobinHatesYou
by TobinHatesYou
I think he is asking if Blendr accessory mounts can be used with non-Blendr bases. The answer is yes, either way. It’s just a GoPro-style mount on both ends.
FIJIGabe
by FIJIGabe
Yeah, I just re-read it. Blendr is just a standard GoPro mount.
sennder
by sennder
You could post here. WheresWaldo should be able to design something for you.
--Sennder
Konsi
by Konsi
Tue Apr 23, 2019 7:52 pm
Yes, exactly. I have a stem (Ritchey C220), for which a GoPro-mount exists, and I would like to attach my Garmin on it, so I could use the blendr-Garmin-mount. I will ask in the other thread though if there is a more elegant solution without 3 joints.
groover08
by groover08
I have this one and it works great: https://www.shapeways.com/product/4WANG ... opro-mount
