Convert record eps rim to disc
Zoeyzidane
by Zoeyzidane
Apologies in advance if this has been previously asked. I searched but couldn’t find anything.
I have a record eps v3 rim brake groupset which I bought in mid 2016 with neutrons wheels.
I know I will need hydro shifters, calipers, rotors and possibly a new crank.
What else do I need to convert these to the eps disc?
Trying to work out whether to go disc on new bike or keep it as rim.
Thanks, Mick
joejack951
by joejack951
Are you will to use mechanical disc calipers? TRP HY/RD or Juintech R1 are both options that would save you from having to buy new levers and offer near hydro brake feel. Crank should be fine. I am using a 2016 Chorus crank on a disc frame with 410mm chainstays and don’t have any chainline issues.
Zoeyzidane
by Zoeyzidane
joejack951 wrote: ↑
Tue May 22, 2018 11:35 pm
I didn’t know I could use mechanical disc. I thought it was hydraulic.
joejack951
by joejack951
Zoeyzidane wrote:I didn’t know I could use mechanical disc. I thought it was hydraulic.
Campy’s disc groups are all hydraulic. But that doesn’t prevent you from using a set of regular levers with mechanical disc brake calipers. The benefit of the two calipers I mentioned is that they are mechanically actuated but have hydraulic internals. This greatly improves brake feel in my experience and the pads auto-adjust as they wear vs. manual tweaking with a full mechanical caliper.
Zoeyzidane
by Zoeyzidane
Thanks. I am still considering options and it will come down to cost.
Do I need to get new wheels or can I fit the rotors onto the current wheels via a new hub?
joejack951
by joejack951
I am not certain but I believe your wheels use fairly proprietary hubs so the chances of finding a disc-compatible replacement are quite slim. Someone else may know more.
2lo8
by 2lo8
Hubs are pretty expensive to replace anyways. Basically the only thing you keep is an old used rim. I wonder how essential a new crank is too. It will surely give better chainline, but it's not like road chainsets haven't been used with 135mm spaced rears berfore.
[6.6kg of no carbon fiber]
[2lo8.wordpress.com]
ooo
by ooo
front disc brake (Juintech R1), rear rim brake
saves a lot of $$ and also weight
Miller
by Miller
ooo wrote: ↑
Wed May 23, 2018 10:04 am
Yebbut it'll look crap.
Frankie - B
Administrator
by Frankie - B
The juin tech options offer NEAR hydro feel. If you are going to take the plunge, get full hydro. The h11 cracks aren’t needed, but give an optimized chainline for hydro as everything on the back moves a bit more to the right.
You would indeed need a disc specific frame and wheels as well.
Please follow me on Instagram
jih
by jih
Yup. It’d be a lot easier to just keep what you have and get discs on your next bike since you’ll be replacing most of the bike anyway.
Once you’ve replaced the frame it isn’t really upgrading a bike.
I suppose you could have a mechanical disc front and rim rear if you replaced the fork but kept the same frame. The front brake is more important anyway so could work well
