Need recommendations for top end sprinter bike to replace Madone 9
- WonderSausage
I have had it with my Madone 9* and I need some recommendations for a replacement.
Profile: I'm a 78kg puncheur with big sprint watts. I'm at my best with lots of short climbs (ideal 10m per km) and tight crit-style curves. I ride most of the time with the rear brake quick release open since I rub the pads like crazy, and even rub 25mm tires on frame due to wheel distortion. Rear spokes ping like a harp.
Bike Priorities:
- Stiff, stiff, stiff (did I mention stiff)? Did the 2018 Tour aero bike test include stiffness? I am not sensitive to ride quality
- No proprietary handlebars (I prefer the super flared Enve Aero Road)
- Di2, not eTap
- At least "medium aero", e.g. F10-level of aero is fine
- While not absolutely necessary, 30mm crank spindle compatibility would be nice
- I don't need disc brakes but I'm toying with the notion that they would eliminate pad rub
- Available in USA with reasonable service network (e.g. not Look)
- Price is not much of a concern
thanks!
* Why am I fed up with the Madone 9? Three problems: 1) Proprietary handlebars with no flare at all, and my specialty is uphill sprints, so I keep bruising my forearms sprinting in the drops. I swapped out the bars for 40cm but that didn't help much. 2) Proprietary seat clamp and I've worn out my Bontrager Paradigm which they don't make anymore. I never liked it very much but at least it was the closest Bontrager came to a Toupe. I want to run my damn Toupe saddle without wrapping crap around the rails to fit in 7x10. And finally, 3) It may be aero but I don't like the handling as much as my previous Madone 7. A big reason I went with the 9 is because the H1 was still made in USA, and I gather that isn't the case anymore, so it's a level playing field now among Taiwanese-made bikes.
Also it's a PITA to service, and the rear brake in the traditional position rubs more for me than it did on the Madone 7 under the BB.
Bike Priorities:
- Di2, not eTap
thanks!
Sagan won sprints on Cannondale and Specialized
Cavendish won on Specialized and Cervelo
Kittel won on Giant and Specialized
I'm sure you can find top sprinters that ride all the other major brands.
Find one that fits you best and that's the one that's best for you.
2015 Trek Emonda SLR Project One - Red eTap - Zipp 303 - 6.48kg
2016 Cannondale SuperX Rival CX1 - 9.29kg
iRide4Sue.org Please Donate to fight Cancer. $27,000 raised in 2017
Get some wheels built for you
I guess the top sprinters got special lay up instead of offtheshelf commercial samples. Plus, Sagan went even further and got his own frame moulds of SuperSix and Synapse...oldnslow2 wrote: ↑Sun May 20, 2018 3:30 amSagan won sprints on Cannondale and Specialized
Actually. If you need something this specific and price isn’t a concern why not look at custom?
They are selling limited numbers of them.
The new Giant Propel SL Disk is really, really, stiff. My Bianchi Oltre XR4 is exceptionally stiff, yet somehow, comfortable. Having said that, I just cracked my Vision integrated bar on the Oltre
Bianchi Oltre XR4, De Rosa SK Pininfarina, Trek Madone SLR, Giant TCR Advanced SL, Cervelo R5 Disk, Giant Revolt
i just got the Propel SL Disc 1 and the seatpost seems to be the stiffest I've ever seen... at least it's much stiffer than my TCR SL Disc. The front end feels much more "compliant" relatively speaking
Check out a Gaulzetti either the Aerotack (carbon) or Interclub (aluminum) and pair this with a set of handbuilt wheels (soldered spokes too).
http://gaulzetti.co/models
These are custom frames but at a reasonable price. Craig does awesome with the geometry and I'd be shocked if you could flex either of these, they'll work with you on the geometry to get it dialed. I love my Interclub, I won't go back to carbon after riding it. These can be setup with either rim or disc brakes.
Last edited by LittleSprinter on Mon May 21, 2018 1:23 pm, edited 1 time in total.
