Dogma f8 crack
markyboy
by markyboy
As per title f8 crack on non drive side chainstay,it looks like just the paint but after only half a dozen rides and only 4 months old i would like a replacement.
I have spoken to the shop i bought it from and sent them the pics and they said they will look into it,i persume they need to contact pinarello.
Colnago master with campagnolo super record 12
Pinarello f8 with campagnolo super record 11
Eddy merckx 69 ultegra disc winter bike ultegra r8000
AJS914
by AJS914
It looks like residue from where a sticker was removed. Do you need a ridge with fingernail?
TonyM
by TonyM
Doen’t look like a crack to me on that pic.
Can you see the carbon?
markyboy
by markyboy
AJS914 wrote:
Fri May 18, 2018 8:09 pm
If you run your fingernail over it you can feel the ridge
jekyll man
by jekyll man
Try wiping it with wd40.
It does look like sticker residue as mentioned above. It even looks like a rectangle with my bad eyes.
Official cafe stop tester
avispa
by avispa
markyboy wrote:
Fri May 18, 2018 7:22 pm
...f8 crack on non drive side chainstay...
By the looks of the paint quaility on your picture, it almost looks like a Chinese copy! Not sure if what you have is color scheme 685, but that silver surely looks cheap! Do you have a serail number and registered the bike at pinarello.com?
If so, you may be in good luck!
TonyM
by TonyM
Yes now that you have pointed it, the print looks indeed like a sticker and like a Chinese fake Pinarello. The Dogma is certainly the most copied fake bike sold worldwide. If you buy a Dogma you should only buy it from a certified Pinarello dealer!
If it is really a genuine Dogma then the quality of this frame is not really good in terms of paint.
markyboy
by markyboy
avispa wrote:
Mon May 21, 2018 2:34 pm
Yes i have a serial number and yes its been registered with pinarello,the photo is a poor one to be honest as the bike in the flesh is stunning paintwork.
leandrofresh
by leandrofresh
I would like to see more pictures. Isn't it a chain protector sticker?
Can you hear cracks or noises while you ride?
2old4this
by 2old4this
markyboy wrote:
Sat May 19, 2018 5:14 am
To me, it looks like a crack where two carbon tubes are connected (otherwise, it is just too coincidental to be nearly flat paintcrack perpendicular to the chaintay. :noidea: )
fh8425
by fh8425
IMO it does look like a sticker edge to me. I check mine, it like this
Hope it can help you.
markyboy
by markyboy
Its defo not sticker edge,i have contacted pinarello just waiting to hear from them.
Bridgeman
by Bridgeman
Have you done the tap test? Take a coin and tap around and over the line, including the opposite side.
I had a near identical situation to yours and my LBS did this and the various and distinct sounds yielded by this procedure was enought for them to send the frame back to the manufacturer. They deemed it was cracked and the frame was replaced.
TonyM
by TonyM
Bridgeman wrote:Have you done the tap test? Take a coin and tap around and over the line, including the opposite side.
Was it a F8? How old and how many Kilometers on it?
Bridgeman
by Bridgeman
TonyM wrote:
Thu May 24, 2018 6:20 am
It was not an F8. My frame was within warranty so the replacement went smoothly.
