Modifying shoes for Speedplay?
Monkeyfudger
by Monkeyfudger
It annoys me that my “aero” cleats stick out so far, I know it won’t make a difference to the actual aero but it looks rubbish and I’m bored. Has anyone ever modified a carbon sole to directly mount the cleat to the shoe like a proper Speedplay compatible shoe?
It should be easy but......
Frankie - B
Administrator
by Frankie - B
It cannot be easily done as the sole is arched and the speedplay cleat is flat. Shoes that are directly compatible with speedplay have a flat part in the sole.
Please follow me on Instagram
sungod
by sungod
there's an add-on bit you can get that fits around the 3-hole adaptor to fill the gap...
https://www.excelsports.com/main.asp?pa ... =5&minor=6
i never bothered as i need a cleat shim on one foot plus wedges, so i'd still end up with gaps, but if you've no shims/wedges they should fit fine
Monkeyfudger
by Monkeyfudger
Never seen those add-on adaptors before, cheers for that!
tabl10s
by tabl10s
Frankie - B wrote:
Sat May 12, 2018 8:03 am
I always wondered what the difference was.
2016 Orbea Orca OMR:
15.0lbs/6.804kg.
2013 Wilier Zero.7:
13.02lbs/5.906kg.
2016 Rca:
11.07lbs/5.048kg.
2015 Pinarello F8(build in-process).
TheKaiser
by TheKaiser
Monkeyfudger wrote:
Fri May 11, 2018 9:36 pm
I've modified soles to mount speedplay cleats further rearward, but used their aluminum 3-hole baseplate adaptor. The process is similar to what you are asking, as the adaptor is flat, and I had to drill out the shoe for the 3 hole pattern and then build up the sole such that it had a relatively flat surface. I considered skipping the adaptor altogheter and just doing a direct 4 hole mount, but went this route as it allowed more for/aft adjustability. Might do a direct mount next time around though.
Basically, it could be done, but would require a high comfort level with a dremel, drill, and some sort of expoxy or heat moldable plastic to create the flat platform on the sole. I prefer the heat mold stuff as you can more easily rework it if you dont nail the alignment the first time around.
eric01
by eric01
I think by the time you're done with all of the mods you'll have a protrusion as tall as what you have today.
AX Lightness Vial Evo, Carl Strong Titanium
shimmeD
by shimmeD
Back in the days I bothered with Speedplay I used the Northwave Speedplay Adaptor Kit quite successfully (for the low stack). There is a post right here on WW: search! :welcome:
Less is more.
