ETAP system weight vs RED mechanical
mike001100
by mike001100
Hi,
yes, I have searched... looking for an answer:
What is the weight difference between SRAM ETAP and RED mechanical on the bike? I mean overall system weight, i.e. bike weighed before and bike weighed after?
I have read that the difference is 40g (someone commented that ETAP made his bike "40g heavier") while others have mentioned that ETAP made their bikes lighter (VENGE, where a whole length of outer is used).
All in all, which one can be made lighter of the two? For example, if I use polymer cables or iLinks or similar with mechanical, will it be lighter than ETAP?
Thank you.
NiFTY
by NiFTY
eTap w batteries
shifters 260
FD 162
RD 237
= 659
Sram Red Mech
Shifters 280
FD 70
RD 145
= 495
Cable weights 71->151g. (102g for ilink)
https://fairwheelbikes.com/aican-bungar ... cable-kit/
eTap = heavier
Johnny Rad
by Johnny Rad
Looking back, my old bike gained just under 1/3 lb or <150g moving from Red10 w/iLinks and carbon bar clamps to eTap11.
wheelbuilder
by wheelbuilder
I went from Red22 mechanical to etap. Don't have documentation anywhere to prove it, but I think I gained about 140 grams.
DWatkinsBSB
by DWatkinsBSB
My sub 5 kilo bike project begun with eTap and moved to Red 22 mechanical. I've got weights of everything and scale pictures at home. Drop me a PM so I won't forget and I'll post everything here, including individual cable weights and outers (some weird stuff, Aican Bungarus outer for gears and that Tune Bowden brake outer inner story for the brake outers. If you know what I'm talking about that weird phrase made sense :lol: :lol: :lol: ).
Kaboom
by Kaboom
Around 150g? SCREW THAT!
I was toying with the idea of upgrading to etap but that's definately outta the window now. I'm sub-6 now and at this point every 50 grams saved come with significant disadvantages or huge outlays, I already find it hard to live with the 170g extra that the Vector 3 pedals are costing me compared to some pimped Speedplays... They're only there cuz I can't live without double-sided power.
jih
by jih
It’s up to you to decide what your priorities are, but for me it was worth it. It’s not that much heavier and is really nice to use.
ChiZ01
by ChiZ01
150g is the difference between $200 crankset and $1000 crankset
RocketRacing
by RocketRacing
150g is like having a piss. I’ll take the hit gor front derailier shifting.
Go single sided vectra and xpedo thrust ti sl on one side. Same q factor, stack, float, etc. But cleat mechanism is different, so you need mismatched cleats.
You know your left/right balance, so one meter will be fine.
