KMC quick link on a Shimano Chain: heresy ?
LouisN
by LouisN
I like to use a quick link on my chains.
I have always used KMC X10SL chains on my 10 speed setups with success.
Now I will switch to 11s this week, I want to try the Shimano HG901 chain, but still use the KMC ( 11S that is) missing link.
Anybody use this setup ? Any feedback would be appreciated.
Thanks for the tip !! :beerchug:
Louis :)
Calnago
by Calnago
Shimano 11sp chain’s now come with their own missing link. So it’s not missing anymore. And they work really well.
alcatraz
by alcatraz
Check for play around the link. My experience is that if there is obvious play you will quickly ovalize the inner links that the link connects together.
Ovalized inner link holes will quickly make the chain longer around the link and cause jumps/skips when it rolls off the cassette. Changing links won't help either.
If you hot wax the chain then put it closed in the wax, not open. Helps a little.
To check the condition of your chain later check both in a section without and with the link and compare the result. It should be similar.
/a
Bigger Gear
by Bigger Gear
As Calnago says, Shimano now has its own 11 spd quick link. But before it was released I was using the KMC 11s link with Shimano 11spd chains with zero problems. In fact, the Shimano and KMC links are almost identical to my eye. Just beware that neither are technically re-usable, so if you remove one it is suggested to replace with a new one.
joejack951
by joejack951
I'm using SRAM 11 sp. Powerlock links with both Shimano and Campagnolo chains with no issues. I have used KMC 10 speed links with Shimano 10 speed chains for years, too.
kode54
by kode54
Bigger Gear wrote: ↑
Tue May 08, 2018 3:10 pm
The Shimano quick links require chain link pliers to install and remove. the KMCs do not and are not quite so difficult to install or remove. i like the new Shimano ones...at least i can tell they are ON sercurely.
- Parlee Altum + DA9150 + Enve SES 4.5 Ene carbon hubs
- Parlee ESX + DA9150 + THM SRM PM + Enve SES 7.8 carbon hubs
- Moots Vamoots Disc RSL Titanium + DA9170 + Enve 4.5AR CK CL hubs
- Argonaut Spacebike 2.0 + DA9170 + Enve SES 5.6 DT Swiss 240 CL hubs
Calnago
by Calnago
It's worth it to get a pair of the new (maybe not that new, but I just got some not too long ago) pliers for those links from Shimano. They work perfectly for both opening AND closing the link. I have a Park tool but it was only for opening and still doesn't work as well as the Shimano one.
PsyDoc
by PsyDoc
Shimano's quick link is definitely a PITA to remove by hand. I still like to use the Connex link, which is really easy to install/uninstall by hand and I have reused them (2-3 chains) without incident...knock on wood.
LouisN
by LouisN
All right. Thanks for all the info guys :beerchug: .
Got two chains this morning.
Maybe I'll try my KMC links first before investing on another Shimano tool ....
Louis :)
MyM3Coupe
by MyM3Coupe
LouisN wrote: ↑
Tue May 08, 2018 6:11 pm
Louis :)
You can get a set of remove/install tools (KNC made) off ebay for not much at all. And the Shimano link is very well made with nicely beveled edges. Much nicer than the KMC ones for sure.
Calnago
by Calnago
^This... I don’t know why anyone would even consider using a non Shimano quick link on a Shimano chain anymore, now that Shimano is providing their own. The chain is such an integral part of the whole shifting system, the plate thickness, the bevels on the edges, etc etc. all play into how well all the mechanical parts interface with each other.
LouisN
by LouisN
I already have the Park tool MLP-1.2 tool, but from what I read, it doesn't seem to work that well.
We'll start from there then: Install the original link with the Park Tool....Spoil alert: New brand, never seen here, coming soon in the Gallery section. At least you know it's going to have a Shimano chain :lol:
Louis :)
dogrange
by dogrange
Man, tough crowd. I indiscriminately use KMc, SRaM and Wipperman quick links on shimano sram and Campy chains with no discernible effects. I also use sram shimano and Campy chains on the three drivetrins pretty indiscriminately and all works well!
Bigger Gear
by Bigger Gear
FYI you can install the Shimano link by placing the chain on the big ring and the 5th cog, then rotating so the link is on the top behind the chainring, then hold the brakes and push down on the pedal to snap the link into place. I've done it a few times, zero problems. This was the SRAM Powerlock method. For removal I use the Park MLP-1.2.
MyM3Coupe
by MyM3Coupe
Tue May 08, 2018 9:10 pm
Unless ur on food stamps most would spend a few bucks on a tool that makes stuff infinitely easier.
