I bought a new road disc frame and seperate an new disc fork.
Only fork is 1.5" Tapered and frame Tapered 1 1/8" - 1 1/4
Fork = Hylix disc Size: 700c, Steer tube Diameter: 1 1/8"(Top) to 1.5"(Bottom), Rake : 43mm, Axle to Crown length: 367mm
Frame= Cube Litening C:62 Disc Frame 2017
Is this combination possible?
Fitting 1.5" Tapered fork in tapered frame Tapered 1 1/8" - 1 1/4
It looks like that frame has an IS47 lower headset, which can not be used with a 1.5" crown fork.
https://www.ebay.com/itm/FPO-Tapered-He ... 2733598925
But check with them, as the lower bearing doesn't seem to be 1.5
Cysco Ti custom Campy SR mechanical (6.9);Berk custom (5.6); Serotta Ottrott(6. ; Anvil Custom steel Etap;1996 Colnago Technos Record
