New Time Xpro vs. Xpresso pedals
boots2000
by boots2000
Is there a trick to prevent TIme pedals from creaking?
I have a new set of Xpro 10 pedals with new cleats- They always creak.
Is there any way to prevent that? Or is that just the nature of Time pedals?
Kayrehn
by Kayrehn
Not sure about creaking, mine was squeaking a bit. Sprayed a bit of lubricant on the platform and smeared it around my xpresso pedals and the noise never came back again.
2old4this
by 2old4this
boots2000 wrote:
Wed May 09, 2018 3:15 am
I clean the pedals and the cleats with Goo Gone. Gets rid of the creaks...
avispa
by avispa
boots2000 wrote:Is there a trick to prevent TIme pedals from creaking?....
In the past I’ve tried many things.... talcum powder, surfboard wax, etc.
However, I have found this product to be the best:
http://www.finishlineusa.com/products/s ... -lubricant
I hope it helps...
TonyM
by TonyM
I hope it helps...
Good recommendation! Image
I bought one bottle and applied it on the pedals and cleats and the noise I had in the right pedal/ cleat is gone !! ImageImage
Let’s see now how long it stays quiet.
avispa
by avispa
TonyM wrote: Let’s see now how long it stays quiet.
On my pedals/cleats it lasts a very long time. I have only had to reapply it if I get caught in the rain or if I wash the bike and the pedals get wet.
Good luck!
TonyM
by TonyM
Good luck!
Good to hear as the bottle is not that big and the pricing not that cheap. But that’s all relative.
BdaGhisallo
by BdaGhisallo
CrossRob wrote:
Mon May 07, 2018 10:09 am
Can anyone confirm whether the XPros use the same cleats as the XPressos?
In a couple of places, I've read that the XPro cleats are more durable, but in others it suggests they're the same cleat.
If they are different, are they on sale anywhere? A few pages of Google results didn't show any.
I have just picked up a pair of Xpro 10 pedals and also bought a extra set of cleats.
The cleats that came with the pedals are noticeably different. The underside (the side that mates with the shoe sole) of the cleat is differently constructed with what looks like different material down the center of the cleat. The toe on the pedal supplied cleats is also wider than the older version of the IClic cleats I got. Another difference is two little bumps on either side of the cleat just in front of the rear bolt slots on the new ones vs the shallow pyramid shapes knobs on the old. The new cleats also have a 'L' or 'R' printed on each cleat just below the front bolt slot. The older cleats don't have that. The Q factor is widened by mounting the 'R' cleat on the left shoe and vice versa.
The new cleats are also wider. I measured the old at 56mm across the widest section across the rear cam. The new cleats measure 59mm wide at that same spot.
In the pics I've included, the new cleats that came with the Xpro 10s are on the right.
Edit: To be sure, the older Iclic cleats will work fine with the Xpro pedals but the cleats supplied with the pedals are different in shape and dimension but do function the same.
BdaGhisallo
by BdaGhisallo
avispa wrote:
Tue May 08, 2018 5:30 pm
glepore wrote:
Sat May 05, 2018 2:19 pm
i'm still curious as to whether they eliminated the bushing in favor of a bearing.
I just got a pair of the XPRO 12's and examined it as much as I could. I like the new rounded edges and the fact that one can remove that ugly cover they now come with. I also noticed a "grease port", so I would think they have bearings rather than bushings. I do hope that the new plate will last longer or as long as the old one as the new one seems to have more plastic and appears more fragile.
At this point, I think the XPRESSO 12 is a great buy if on sale. It is 80 grams with the Ti spindle, while the XPRO 15 is 88 grams and the XPRO 12 94 grams. The other thing that confused me is the new cleats. On a PDF brochure I received, Time said they now have Fixed and Floating cleats. But I received the fixed cleats with my pedals. When I read the isntructions that came with the pedals, there was no mention of a fixed cleat, just "one kind of cleat".
I love Time pedals a lot but man I find them really fragile sometimes.
Are you sure you have the fixed cleats? The reason I ask is that the normal 10deg float cleats supplied with the Xpros look like the fixed cleats in that the toe is wider than the traditional Iclic cleat supplied with the Xpresso pedals. The new fixed cleats have the words 'fixed cleats' written on the body of the cleat just behind the front bolt slot.
avispa
by avispa
BdaGhisallo wrote:Are you sure you have the fixed cleats? The reason I ask is that the normal 10deg float cleats supplied with the Xpros look like the fixed cleats in that the toe is wider than the traditional Iclic cleat supplied with the Xpresso pedals. The new fixed cleats have the words 'fixed cleats' written on the body of the cleat just behind the front bolt slot.
No "FIXED CLEAT" words on mine, so I should have the ones with float.
I am wondering if anyone can order the pedals with fixed cleats or if they all come with the floating pedals and the fixed cleats have to be ordered separately...
BdaGhisallo
by BdaGhisallo
avispa wrote:
Mon Jul 30, 2018 5:43 pm
Almost 100% certain that the fixed cleats are after market only.
Wingnut
by Wingnut
Any more feedback the the Xpro's especially with regard to the bearings? Are they holding up and still smooth?
avispa
by avispa
Wingnut wrote:
Mon Sep 03, 2018 12:47 pm
Two months (2300 miles) of solid use on my XPRO 12's and zero issues. I've done also different kinds of workouts on them: intervals, sprint, hill climbs, etc. I find them a bit more solid and comfortable than the Xpresso. I like the new platform size as well... I confirmed the cleats from the Xpresso work well with these pedals too...
BdaGhisallo
by BdaGhisallo
avispa wrote:
Wed Sep 05, 2018 10:52 pm
Still working well for you? How are the cleats holding up?
