Light crankset BB30 for Shimano
Hennesy
by Hennesy
I'm searching a light crankset to use with Dura Ace DI2 with bb30 bottom brackets.
Any ideas ? I don't want to spend too much like THM
TwiggyTN
by TwiggyTN
Lightning is a good choice. I've had one for many years with Praxis rings and it's been rock solid. Same for a teammate of mine.
Sent from my SM-N920V using Tapatalk
Hennesy
by Hennesy
the best option should be Sram Red + Extralite Octaramp, but i don’t like to mix shimano group with sram crank ( Ugly :| ).
I’ve also the possibility to use my old Hollowgram Si crank, but it’s heavy 615Gr.
alcatraz
by alcatraz
How about running a shimano crank and use a bb30 to shimano bottom bracket. It won't be the lightest but it'll look good.
Lightest (apart from thm) is sram red, and you can sand down and clear coat it so it's clean carbon looking.
You can put fsa sl-k or cannondale si sl. For good shifting you just need the right chainrings. Try to figure out which chainrings work best with di2 perhaps.
/a
happyon2wheels
by happyon2wheels
FSA K-Force Light (BB386 as they call it) has impressed me even in direct comparison to DA 9100. Not exactly cheap, though, but certainly well below THM price range.
They are fairly light at 590g including spacers (172,5mm 34/50).
I now run DA on C- Bear bb30-24 bearings and am very happy with the setup, both in terms of performance and looks.
Hennesy
by Hennesy
alcatraz wrote:
Wed May 02, 2018 5:52 am
/a
With Shimano crank + Praxis adapter the weight is 700Gr.
It's a good idea to use Sram crank, sanding etap brand. Maybe putting a sticker on it
Denavelo
by Denavelo
Edited, no unsolicited advertising please.
Speedvagen Road Machine "2011 Surprise me | Cannondale SuperSix Evo | Rob English "Mudfoot" 29er | Firefly Ti #419 | Kogswell 650b Rando | Crema Cycles "Duo"
Hennesy
by Hennesy
I need 170 mm cranks
Rick
by Rick
SRAM Red BB30 is pretty light (although I have no idea how close to the LIGHTEST)
But I can attest that it works perfectly with an otherwise all Shimano setup.
Hennesy
by Hennesy
Rick wrote:
Wed May 02, 2018 8:51 pm
Extralite Octaramp works fine too ?
NiFTY
by NiFTY
Sand down a sram red crank. I have done exactly this. My sram red 130 172.5 with all spacers, a stages spindle and stages nds power (also sanded) with chainring bolts and 53/39 q rings ( not light chainrings) was 560g.
beanbiken
by beanbiken
Another option is to vinyl wrap the crank arms if you don't want to compromise warranty. it is easily reversable & the weight added is minimal. I did this to a DA9000 crank and from a short distance it is invisible
BB
BB
Coffee & carbon
nickf
by nickf
I'm really liking my lightning cranks. 172.5 with extralight octaramp mc rings it comes in at 490g.
wheelsONfire
by wheelsONfire
One more for FSA K-Force Light, i've got two of them and they work perfect.
Also got Easton EC90SL (but with a Kent Eriksen spider) and Wickwerks 44/34 CX combo.
Bikes:
Open *UP* (2016.04.14)
Ex bike; Vial EVO D
Beaver
by Beaver
+1 for SRAM Red - best weight/value for money and no proprietary chain rings needed.
