Hello, I plan to upgrade my road bike (Felt FC1) from SRAM RED 10 to SRAM eTAP.
Does a chainring combination 46/36 X-Glide work with the eTAP front derailleur and the eTAP wifli with 11/32 cassette ?
On the SRAM webpage I find following chainring combination: 53/39; 52/36; 50/34; 46/36
Based on above, is it wrong to say that it might work also with a 46/34 chainring combination ?
Is anybody running SRAM eTAP with 46/36 or 46/34 chainring combination ?
Thanks,
Alexander
SRAM eTAP chainring combination
Yes it works with 46/36. That is Wout Van Aert uses for racing cyclocross with eTap.
It would work with 46/34. But the shift ramps on the 46 ring are not optimised for use with a 34 (only a 36). So SRAM would say that will compromise performance. I doubt you'd notice anything in the real world.
On my bike I have to position the FD all the way down the braze-on tab to get the appropriate clearance with 50/34. With 46/34 you might have an excessive gap, but shifting should only be minimally affected. Maybe the occasionally chain thrown over the big ring.
Thanks for feedback so far, which supports my idea to go with a 46/34 combo on my SRAM eTAP build.
I will buy a 36 chaninring as "back up" solution anyway....
Hope the mechanics from the bike shop can make it working fine. I will report back about the outcome. Happy to be part of a forum where you get some good support from others. Thanks !
