Gxp sram red big problem can you solve it?
flostonf00
by flostonf00
Frankie - B wrote:
Sun Apr 29, 2018 5:36 pm
Yep, thats the one.
flostonf00 wrote:
Sun Apr 29, 2018 5:29 pm
i think i found it!Am i right?
https://www.bike24.com/1.php?content=8; ... ,81;page=4
i can see they have the full list this is super nice!
https://www.bike24.com/1.php?content=13 ... uring+BB30
Frankie do you think i need to buy separate from wheels manufacturing any outboard spacer kit or wave washer?
Frankie - B
Administrator
by Frankie - B
I don't think you need any extra washers for the screw type bb. Just pop the bb30 bearing out of the frame and install the Wheels mfg one. Then install the crank (wave washer on the drive side) and you are done.
Please follow me on Instagram
Lelandjt
by Lelandjt
I have the same frame and crankset but BB30. My advice is sell that crank on ebay and buy the BB30 version. They're fairly cheap, lighter, and it works perfectly with no monkeying.
wheelbuilder
by wheelbuilder
2lo8 wrote:
Sun Apr 29, 2018 4:54 am
wheelbuilder wrote:
Sat Apr 28, 2018 11:46 pm
If everything else above is correct, start with the wavy washer on the non drive side.
Doesn't the wave washer go on the drive side for GXP cranks? With the proper 22mm NDS bearing, the bearing is pretty much fixed to the crankset, so there's nothing for a wave washer to do on the NDS. The DS bearing is normally free floating, and the wave washer prevents bearing drift.
YES! You are absolutely correct. My whole post is a disaster but you get the idea. I was thinking of PF30, GXP, and everything else when I was posting that. Totally wrong.
flostonf00
by flostonf00
Lelandjt wrote:
Sun Apr 29, 2018 5:57 pm
Already spent alot of $$$ on parts carbon things wheels framesetand i am tired of selling this and buy a new one now...
If you have the same frame what's the complete bike weight ?
Lelandjt
by Lelandjt
I have the 61cm with all aero parts and it's 6.6kg. That's a 2016 Transonic SL, right?
flostonf00
by flostonf00
Lelandjt wrote:
Sun Apr 29, 2018 7:15 pm
The 2015 i guess
but 7.1kg at the moment
flostonf00
by flostonf00
but 7.1 kg at the moment...
alcatraz
by alcatraz
Bb30 cranks are cheap compared to gxp because they are becoming obsolete because of the short axle.
They are better though if your bike supports them. You might actually make money on the change. :lol:
/a
Lelandjt
by Lelandjt
flostonf00 wrote:
Sun Apr 29, 2018 8:53 pm
The 2015 i guess
I think 2016 was its first year. I ordered mine in December '15 and got it in Feb '16.
flostonf00
by flostonf00
Lelandjt wrote:
Mon Apr 30, 2018 6:54 pm
The 2015 i guess
Yes you are right!!!
I wish i can ask you something about the frame where i can do it?I dont wanna be off topic?
Lelandjt
by Lelandjt
Bah, it's your thread, fire away.
flostonf00
by flostonf00
Lelandjt wrote:
Tue May 01, 2018 7:20 pm
Do you have any pictures of the headset or fork on the bearing side...I am not used with integrated bearings and it seems it wasnt deliver with any aluminium plate so the integrated bearings can move on.But on the fork i see raw carbon very hard and a small "Dig".That;s how they work? i mean i don't think it can harm the carbon because the lower par will stay fix when its tighten and only the inner parts moves but i want to make sure it is ok...
Lelandjt
by Lelandjt
I don't have any photos but I just had it apart to replace the bearings with the aluminum ones that come with the Fuji SL. I don't recal a metal fork bearing race. I think the fork crown was molded to fit the bearing and for sure the frame is molded so the bearings just sit in it. So yeah, it sounds like you have it right. If you want to replace the tall bearing cover to lower the stem I used the thin bearing cover from slamthatstem.com.
topflightpro
by topflightpro
Many (dare I say most) carbon forks these days have the crown race molded into the fork. They no longer require a metal one be pressed on there. So, OP, I think you are good.
