If you are in between frame size, go up or down?
KCookie
by KCookie
As this is WW you have to go smaller, smaller is lighter. That's what this forum is all about. 😀
stockae92
by stockae92
Thanks for all the advise. The head tube length is a concern for me.
My current setup on a 58cm frame is pretty much as low as I would go. I do worry if I go with a smaller size, if the head tube length is shorter, I would have to put spacers under the stem. Or maybe a endurance geometry with taller head tube (in a smaller size frame) would solve the problem.
srshaw
by srshaw
My first real bike was too big, even though for my height it should have been ok. I have long legs and short torso. Most advice seems to be to go bigger, but I have found they then become too long. I'm 5'10 and now usually go 54cm.
Since most manufacturers use stack and reach measurements, Its fairly easy to compare differrent frames.
spdntrxi
by spdntrxi
I've done it both ways... current main bike I purchased for the long haul ( I think anyways) and went up.. if I was to get a predominately "race bike" I might go down a size.
donald
by donald
In general I would go smaller. Do you know what frame you are interested in? Different manufactures have different lengths in top tube and head tubes in the same size frame. It is good to know what the exact dimentions are of any frame you are interested in.
Zakalwe
by Zakalwe
I think the correct practice is to go two, perhaps 3, sizes smaller
pdlpsher1
by pdlpsher1
To make the process easier just find the frame size such that you’ll end up with 180mm exposed seatpost and a 130mm stem. This will give you the perfect bike fit.
Bigger Gear
by Bigger Gear
Zakalwe wrote:
Thu Apr 19, 2018 7:32 am
Exactly correct for the World Tour riders. Two examples I can think of especially stand out: Ryder Hesjedal who is 6'3" or 1.90m riding a 56 cm Cannondale (or Cervelo). His Cervelo looked exceptionally stupid, because of the long head tube. He really needed a custom setup. And also Philippe Gilbert on BMC, he is 5'10" or 1.79m riding a 50cm frame! I have noticed since going to QuickStep and riding on a Specialized that Gilbert's fit has evolved, he's riding a bigger bike and he is a bit more upright.
Just remember that a WT rider's fit means nothing for the average person. They ride over 30000 km each year, and have a dedicated team of sports physios and massage therapists keeping them limber. All of that contibutes to them being able to ride a position the average person (even at an elite amateur level) can not ride.
Zakalwe
by Zakalwe
I wasn’t being entirely serious, btw
bremerradkurier
by bremerradkurier
Bigger Gear wrote:
Thu Apr 19, 2018 5:09 pm
It's kind of interesting to look at mid to late '80s pro positions vs. current ones, especially given the longer format of the TdF pre 1988.
IMO, there start to be some handling drawbacks going the small frame/long stem route, maybe due to how weight loading is distributed on the front vs. the rear wheel.
Bigger Gear
by Bigger Gear
Zakalwe wrote:
Thu Apr 19, 2018 5:14 pm
Yes I knew that but should have indicated it in my response. But it is definitely interesting to see the evolution of bike fit over the years, at the highest level. Guys ride more forward and with much greater saddle-bar drop than 20/30/40 years ago. I suspect having wind tunnel data and image capture fit tools has allowed sport science to figure certain things out on a much higher level.
Zakalwe
by Zakalwe
A lot of that has to do with bar shapes and integrated shifters though, old bikes with little saddle/bar drop had massive drops and there weren’t hoods to rest your hands on. You didn’t need such a low bar height as you do now, where hoods are the primary position for a lot of riders and shallow drop bars are better suited to most needs
morganb
by morganb
Zakalwe wrote:
Fri Apr 20, 2018 1:59 pm
Something interesting from an interview with Viviani, his ViAS has lower bar set up than his Tarmac and he essentially said he can't use the drops on the ViAS for regular riding and only gets in them for the sprint.
themidge
by themidge
Yeah I saw that interview too (I think it was on GCN) and thought it was pretty interesting. If he doesn't feel the need for the drops on his Vias, then I'm not sure why he wants them on the Tarmac, obviously he likes riding on the hoods. Perhaps if there are long descents (ie. hills, not terrain for a Vias) then he wants the extra control of the drops :noidea:.
Zakalwe
by Zakalwe
Maybe he just doesn’t expect to sprint in such a low position in a race where he’s chosen to ride the tarmac
