Rotor Aldhu
- wheelsONfire
I went with the standard axle. Rotor support said that both the standard and offset axle will work but they've seen better shifting with the standard.MrAppleSeeds wrote: ↑Thu Jun 15, 2023 9:51 pmAccording to T*red which usually spec their bikes with Rotor + AXS, they use the standard version. I asked because i contemplated Rotor.
But in the end i went with the standard RED AXS crankset.
But you can always send Boris the question.
borishrusovsky@rotorbike.com
I also spoke with a few people who were running Rotor cranksets with AXS and they said the chainline did not cause an issue so all that is left is for me to see it myself.
I wanted the RED AXS Crankset too because I'm able to acquire a power meter version for almost half the price but SRAM cranksets with the exception of Rival are not able to meet my bike fit. I got the Rotor crank because of the length options they provide.
[/quote]
That make sense! I had in mind going for 167.5mm crank, but got 170mm. I'm not even sure 165mm is available in Europe (RED AXS).
Bikes:
Open *UP* (2016.04.14)
Goy myself a very nice looking Rotor Aldhu crank set.
Somehow the power of my Favero Assioma's reads much lower than on my gravel bike / indoor bike. Set-up the crank length correctly, calibrated several times. But every ride the power numbers are just low (like 20 watts lower average than all my recent similar rides). Swapped the Assiomas to my gravel bike the same day, and numbers made sense again.
What the hell can cause this??
I also use Favero on my Aldhu and no problem at all.Requiem84 wrote: ↑Sun Jul 09, 2023 6:08 pmGoy myself a very nice looking Rotor Aldhu crank set.
Colnago C68- Enve SES 4.5
S-Works Aethos - Enve SES 2.3
Enve Fray - Enve SES AR 4.5
Open MIN.D - Enve SES AR 4.5
Mosaic GT2-45 - Enve SES AR 3.4
Chinese Winter/Rain Bike
Brompton T-Line
Wahoo Kickr Bike
Brompton T-Line
Wahoo Kickr Bike
Brompton T-Line
Wahoo Kickr Bike
Brompton T-Line
Wahoo Kickr Bike
You will definetly need a washer for your Assioma pedals using Aldhu cranks otherwise the pod will touch the arms under load.
This is the definite answer. I also found that assioma on aldhu requires 1 more(2in total) washer for clearance.Requiem84 wrote:Hmm okay, I'll do some further digging. On another forum someone floated the idea that the Assioma pod might touch the Rotor crank. I'll look into that and try a spacer to see if this helps.
나의 SM-G977N 의 Tapatalk에서 보냄
I use the shims between crank arms and pedals because it seems like they would touch on the Rotor Aldhu (not the case with my Ultegra R8000 and GRX810 cranks). Perhaps they are for you as well and they're pressing against the pod?Requiem84 wrote: ↑Sun Jul 09, 2023 6:08 pmGoy myself a very nice looking Rotor Aldhu crank set.
- lord_brush
duplicate
The right to bear arms is slightly less ludicrous than the right to arm bears. (Chris Addison)
- lord_brush
My Assioma Duo's definately DON'T need washers between them and the Aldhu cranks
Gang, I am mulling the idea of getting an ALDHU crankset and round chainrings on my bike (prefer a 48/32 to maintain high rpm when climbing which suits me better). Apart from 24mm spindle, crankarms and one-piece direct mount chainring set, is there any other part I need to buy to replace my Ultegra 2x11 crankset and start riding? Did I forget anything (eg bolts, washers, etc)?
2020 Scott Addict RC / 2023 Specialized Tarmac SL8 / 2024 S-Works Crux
Crankarms
Axle
When used direct mount chainrings no additional parts are necessary.
Axle
