Sagan's bike at Paris Roubaix
sethjs
by sethjs
<t>Took a close look at some of the photos. Interestingly, I'm pretty sure it's a Roubaix frame with rim brakes and no future shock. The give away is the junction of the seat stays with the seat tube</t>
SilentDrone
by SilentDrone
No future shock? Shocking! That thing seems dubious to me.
bas
by bas
I’m sure I remember they were using the same last year, had a future shock but it was locked out. Rim version for pros only
silvalis
by silvalis
You can also see the roubaix style headset cap in the photos where he was fiddling with his stem with an allen key.
Chapter 2 Tere
Scott Spark 720plus
oldnslow2
by oldnslow2
Ed Zackerly
Rim brake version, locked shock and Zipp stem.
sethjs
by sethjs
And interestingly, mechanical shifting.
cassard
by cassard
this is last year's bike (2017). This year it's the golden version one, but definitely a roubaix with rim brakes and no shock. You see the seatpost clamp on pictuers
silvalis
by silvalis
This
Chapter 2 Tere
Scott Spark 720plus
TobinHatesYou
by TobinHatesYou
oldnslow2 wrote:
Mon Apr 09, 2018 2:27 am
This is a Tarmac. He was on a Roubaix. All the pros were running a special FutureShok with an adjustment dial for a top-cap. This allowed them to adjust the spring from soft to virtually locked out.
Toward the end of the race, he borrowed a hex key from his team car because apparently his stem/steerer clamp bolts were loosening up. The shot of his cockpit showed the dial in detail.
Another key difference of the Pro Roubaix...they have a longer/lower geometry. Kind of like Trek's H1 vs H2, but less extreme.
SilentDrone
by SilentDrone
Just watched the video. Amazing that he was able to tighten those bolts while racing. I wonder how he knew they needed tightening? Seems like the kind of thing that you wouldn’t notice while riding, and that would fail catastrophically if it were to get too loose.
On a side note, I hadn’t seen that adjustment knob for the future shock before. Seems like just what that device needs to give it broader appeal. Im sure they’ll roll those out to consumers in short order.
sychen
by sychen
The lockout is new... Released for this roubaix edition.
I'm sure it'll trickle into production versions shortly.
SilentDrone
by SilentDrone
Why do you suppose he went with the mechanical group set?
zirxo
by zirxo
It's not unheard of for di2 cables to get loose from the shifters in crashes, probably a bit higher probability of that happening during P-R.
