Shimano 105 R7000
ooo
by ooo
https://bike.shimano.com/en-US/informat ... r-ran.html
Shimano’s New 2019 105 Road Components Go Disc, Broaden Gear Ranges, Refine Ergonomics
Employing the latest technology from DURA-ACE R9100 and ULTEGRA road components, Shimano 105 R7000 delivers added versatility and improved ride performance for a wide spectrum or road cyclists. Featuring refined ergonomics, ST-R7000 shift levers match the slim look and feel of Ultegra R8000 and R8020 while the addition of the RD-R7000-GS derailleur and 11-34T cassette expand gear ranges. The biggest news for Shimano 105 is the addition of hydraulic disc brakes with Shimano’s leading disc-specific features to the series lineup. New flat-mount BR-R7070 calipers are compatible with ICE TECHNOLOGIES pads and SM-RT70 rotors (including a new 140mm size) to offer the most capable Shimano 105 group yet.
FC-R7000 Crankset offers increased efficiency with more options
The FC-R7000 HOLLOWTECH II Crankset delivers optimum power transfer, balancing weight and efficiently without sacrificing stiffness. Shimano’s range of Rider Tuned crankarm and chainring combinations expands with the introduction of a new 160mm crank arm and 50/34t ring option.
  • Optimized lightweight crank arm design produces excellent power transfer efficiency
  • Redesigned chainring tooth profiling increases clearance between chain and leading teeth to provide compatibility with frames featuring 135mm O.L.D. and 410mm chainstay length
  • Crank arm lengths: 160mm, 165mm, 170mm, 172.5mm, 175mm
  • Rider Tuned gear combinations: 50-34T, 52-36T, 53-39T
  • MSRP - $159.99
CS-R7000 and CS-HG700-11 Cassettes further expand gearing choices
The R7000 cassette features an increased range of high-performance gearing combinations while the new 11-34T CS-HG700 cassette further expands gearing options for a wide variety of terrain. Designed to fit both MTB- and road-specific (with spacer) wheelsets, the 11-34T gear combination provides mixed terrain riders more wheelset options than ever before.
  • High performance rider tuned gearing with wider gar choices
  • CS-R7000 gear combinations: 12-25T, 11-28T, 11-30T, 11- 32T (MSRP - $50.99)
  • CS-HG700 gear combination: 11-34T (MSRP - $55.99)
  • CS-GH700-11 11-34T cassette also fits 10-speed freehub body
Image Image
Shimano 105 Series new hydraulic disc brakes offer all-conditions control
Utilizing Shimano’s lightweight and sleek flat mount design, the BR-R7070 Hydraulic Disc Brake Caliper features premium stopping power and aerodynamics for road applications. The new SM-RT70 rotor offers ICE TECHNOLOGIES construction for excellent heat management for confident performance on the longest descents.
BR-R7070, Hydraulic Disc Brake Caliper
  • Increased rider control in all conditions
  • Sleek Flat Mount design integrates seamlessly into a road bike’s aero profile
  • MSRP - $69.99 (front), $64.99 (rear)
SM-RT70, CENTER LOCK Disc Rotor
  • ICE TECHNOLOGIES construction provides excellent heat management
  • 140mm MSRP - $33.99
Rim brakes feature sleek design, improved performance and increased tire clearance
Shimano’s legacy of industry-leading rim brake performance continues redesigned Dual-Pivot and Direct Mount models feature new technologies and sleek designs, resulting in improved stopping power and efficiency with clearance for 28C tires.
  • Clear contact feeling with balanced rigidity, weight and stopping power
  • Sleek design with a narrower gap between arms
  • Wider clearance with larger tire sizes (up to 28C)
  • BR-R7000 MSRP - $94.99 (pair)
  • BR-R7010-F (Direct Mount Front) MSRP - $57.99
  • BR-R7010-RS (Direct Mount Seat Stay) MSRP - $57.99
  • BR-R7010-R (Direct Mount Chain Stay) MSRP - $52.99
Refined Dual Control Lever ergonomics and a new “small hand” option for better control and improved precision
Shimano 105 ST-R7000 and R7020 feature redesigned internal shift units for slimmer, more ergonomically shaped control levers that match the design of Ultegra R8000 and R8020. Increased reach adjustment of up to 15mm provides more control and reliable performance in all conditions for both mechanical rim brake and hydraulic disc brake options. The new ST-7025 Hydraulic Dual Control levers offer the same features as ST-7020, but the reach starts 4mm closer and the lever blades allows riders with small hands to comfortably and securely brake without rotating their hands forward to grab the levers.
ST-R7000, Dual Control Lever (MSRP - $234.99 pair)
ST-R7020, Hydraulic Disc Brake Dual Control Lever
ST-R7025, Hydraulic Disc Brake “Small Hand” Lever
  • Redesigned shifting unit for quick and intuitive shifting
  • Increased reach adjustment range (15mm)
  • Slimmed-down hydraulic internals for similar ergonomics between disc and rim brake configurations
  • ST-R7000 MSRP - $234.99 (pair)
  • ST-R7020 MSRP - $309.99 (each, includes lever, caliper, and line)
  • ST-R7025 MSRP - $314.99 (each, includes lever, caliper, and line)
Precise front shifting with wide gear range compatibility
The new FD-R7000 front derailleur utilizes the new link construction first introduced with DURA-ACE R9100 for easy setup and fine-tuning adjustments without the need for specialty tools. The RD-R7000 rear derailleur utilizes Shimano’s SHADOW RD low profile design and will be offered in both SS and GS cages for wider gear range combinations.
FD-R7000, Front Derailleur (2x11-speed)
  • New construction matches the force curve of the hand more naturally to reduce effort at the end of shifting
  • New design allows for more flexible cable routing design
  • Redesigned for disc-specific frames, accommodating a wider gear pitch without sacrificing shifting performance
  • MSRP - $39.99
RD-R7000-SS/GS Rear Derailleur (11-speed)
  • The Shimano SHADOW RD low-profile design increases shift stability and reduces crash vulnerability while providing a sleek integrated appearance
  • Two cage length options provide wide range of gearing compatibility
    • RD-SS covers: 11-25T to 11-30T
    • RD-GS covers: 11-28T to 11-34T
  • MSRP- $52.99 (RD-R7000-SS), $57.99 (RD-R7000-GS)
jorryt
by jorryt
That crankset tho....
prebsy
by prebsy
I love the all black finish on 105, this will be a killer groupset.
Strava
Current Stable:
Specialized Allez Sprint Disc
Cervelo Aspero
Scott Spark 910 Contessa
raisinberry777
by raisinberry777
Looks nice. No surprises, but I don't think anyone expected any.
slake21
by slake21
jorryt wrote:
Mon Apr 02, 2018 11:00 am
kinda looks like ultegra
edit:
backup pictures
jimmerjohn123
by jimmerjohn123
This looks really good. The gap between 105/ultegra has always been small. That explains why Trek put a heavier fork on their 105 Emonda SL5, have to differentiate them somehow.
srshaw
by srshaw
Great how it looks like there are hubs as well, (I'm not aware of r8000 ultegra hubs).
This will look great on my caad 12 disc.
jch3n
by jch3n
Finally. Now everyone can burn their fugly RS505 shifters....kill it with fire!
madik
by madik
Official release date is tomorrow? Article on therider.cc was already taken down
Functionality > Performance > Weight
fa63
by fa63
Looks great, except I wish they offered a sub-compact (48/32, or even 46/30) crank option as well.
ooo
by ooo
They already have sub-compact 46-32 road cranks FC-U5000-2
fa63
by fa63
But not in the 105 series; the U5000 cranks wouldn't match aesthetically.
Nickel020
by Nickel020
srshaw wrote:
Mon Apr 02, 2018 5:49 pm
There‘s the newish RS770 hubs which are Ultegra level, although it‘s strange that those are off-group and a non-matching (although nice) design, while the 105 gets on-group hubs. I guess there‘s no point in trying to understand Shimano‘s „strategy“ here...
ooo
by ooo
@srshaw
rim brake 105 hubs are just 5800 rebrands
12mm rs770 disc hubs are replacing cx70 qr road disc hubs
12mm 105 disc hubs are replacing rs505 qr road disc hubs
@fa63
it's black and silver, how it wouldn't match? and 105 offered in 2 colors, one of them will match
fa63
by fa63
Look at the lines on those cranks; looks like it is made for a city bike. But to each their own; I would rather use a Praxis Zayante or something. Not the end of the world.
