Daedalus vs Enve Seatpost.
tabl10s
by tabl10s
The LBS lost my Daedalus and gave me an Enve. Which is actually better?
2016 Orbea Orca OMR:
15.0lbs/6.804kg.
2013 Wilier Zero.7:
13.02lbs/5.906kg.
2016 Rca:
11.07lbs/5.048kg.
2015 Pinarello F8(build in-process).
Zakalwe
by Zakalwe
List weight of the AX is quite a bit lower
Kumppa
by Kumppa
Enve ~275€ / 204g
AX ~320€ / 146g
Pretty much depends what you think about weight difference and look. How its even possible to lost seatpost?
Frankie - B
Administrator
by Frankie - B
I think the deadalus is better built. Handmade in germany! IDK, but i think i would feel ripped off in this deal. How old was that deadalus?
Please follow me on Instagram
billspreston
by billspreston
What kind of LBS loses a customer's $300+ component and then replaces it with a different, sub-standard component :noidea: Sometimes this industry really bums me out. Mistakes are made, but the good shops know how to make it right. This LBS does not and I would be dissapointed on multiple levels in your case.
guyc
by guyc
Like for like I’m afraid. They’re having a laugh.
Zakalwe
by Zakalwe
Maybe worth checking the lbs staff bike racks to see if there’s any there with your Daedalus
spdntrxi
by spdntrxi
tabl10s wrote:
Wed Mar 28, 2018 3:58 pm
you mean borrow the enve until they get you another daedalus :wink:
sychen
by sychen
Oops lost your BMW M3.. Here is a 330i.
Dude..that is Not ok.
Loaner enve.. Sure.
Calnago
by Calnago
Yes, unless YOU are totally ok with the swap, then it’s up to them to provide you a new one. I’m with @billspreston, what kind of shop “loses” an expensive component. If they can’t “find” it, then buy the customer a new one.
tabl10s
by tabl10s
It was about 6 years old and no longer on the website anymore(I got it free with the frame). I saw a nice one in a 31+, but wouldn't fit.
15.0lbs/6.804kg.
2013 Wilier Zero.7:
13.02lbs/5.906kg.
2016 Rca:
11.07lbs/5.048kg.
sychen
by sychen
If they lose it.. Need to be like for like.
Do not settle for anything less.
"Losing" a seatpost (that is probably uncommon in your area) sounds dodgy as hell.
robertbb
by robertbb
Nest they'll give you a fake ENVE...
Get them to compensate you with a new Daedalus in your measurement, or the value of their equivalent model today (and not as store credit either!).
Then ditch the shop.
spdntrxi
by spdntrxi
if you are ok with... you are ok with it. It's not like the enve post is a POS.. it's not. But they should give you some options.
tabl10s
by tabl10s
spdntrxi wrote:
Thu Mar 29, 2018 4:05 am
I made a deal with the head mechanic. He has worked on my three bikes exclusively and even upgraded the seatpost on the first bike after the bike fitter installed the saddle on original incorrectly.
As I've mentioned before, the Daedalus was free with the frame(used)and now I get a new post and a break on the build(normally $300). Push-come-to shove, I can install the Enve on a different frame and get what I really want.
15.0lbs/6.804kg.
2013 Wilier Zero.7:
13.02lbs/5.906kg.
2016 Rca:
11.07lbs/5.048kg.
