LED Tail light suggestions
addictR1
by addictR1
Looking for a rechargeable led taillight that can be mounted under the saddle, nicely tucked away.
Anything like that?
TonyM
by TonyM
Lupine Rotlicht!
Here the saddle kit:
http://www.lupinenorthamerica.com/rotli ... _mount.asp
r33prman
by r33prman
Nightflux red4. 100 hours battery life on flash mode. Race ware components make a saddle rail mount. Bloody love mine!
coriordan
by coriordan
Moon Nebula.
Great light
Pretty waterproof
Flash and steady modes
also has a saddle rail mount. Very smart
thorerik
by thorerik
If you happen to have a Fizik saddle, i can recommend their integrated lights.
fh8425
by fh8425
i been using Exposure TraceR Rear Light since i took up cycling few years back. Tucked below my saddle. Easily accessible for power on/off and charging.( been thru san marco, selle italia, specialized and finally now fizik saddle). My currrent fizik's model is without the integrated light system, the light mount is mounted on the rails.
kode54
by kode54
^ is that a special mounting bracket for the seat rails?
- AX Lightness Vial EVO D + DA9150 + Enve SES 3.4 carbon hubs
- Parlee ESX + DA9150 + THM SRM PM + Enve SES 6.7 CK hubs
- Independent Fabrication Ti FLW + DA9100 + Enve 3.4 CK hubs
fh8425
by fh8425
kode54 wrote:
Tue Mar 27, 2018 6:50 pm
it comes with the exposure rear tracer light when you buy it.
Wookski
by Wookski
r33prman wrote:
Tue Mar 27, 2018 11:06 am
Rad light, fantastic for early winter starts. My issues has been a) the rail mount fits non of my weenie saddles (tune, Berk or WR) and b) the light and mount is ridiculously heavy.
The cleanest solution I have found is a moon comet rear with the saddle rail mount flipped upside down. The light becomes ticked under the saddle and looks almost perfect. I’ll post a pic when I have time.
TobinHatesYou
by TobinHatesYou
TonyM wrote:
Tue Mar 27, 2018 5:45 am
Lupine Rotlicht!
Seconding the Rotlicht. It's compact, bright, has an OK runtime and the elastic band is durable. It has an accelerometer for braking. Also replacement batteries are cheap when the time comes.
Squashednuts
by Squashednuts
+1 for the Exposure TraceR
I've been using one for a couple of years
Small but bright
Okay battery life
jorisee01
by jorisee01
Moon LED LX-70. Cheap and works well. Also quite aero
sawyer
by sawyer
The Rotlicht is very good, though is expensive and, while bright, not among the very brightest.
I've tested a lot of these and observed thousands more in use.
Exposure Tracer is very good.
There is something to be said also for a large area light - on a VFM basis the old school wide / tall Cateyes are very good in that regard.
The Moon Shield X it top for brightness /$/£/€
coriordan
by coriordan
Moon Nebula on Fizik Arione 00 with saddle rail mount. The light fitting can also be adjusted so you can have it more horizontal or angled downwards as you wish.
naylor343
by naylor343
If it's to be seen during daylight then I would recommend the exposure traceR. No one can ever say 'sorry I did not see you!'. It fits very neat under your saddle too. Can also be dialled down for night time use. Some one mentioned earlier that it comes with the under saddle mount, but this is not correct, it comes with the seat post mount, under saddle is extra.
