Has anyone found a way to mount the Di2 charging port into the Sl6 frame - same as the BMC team machine ? The tarmac has a port for mounting mechanical shift cables or the port may be blanked off. I have not seen a way to copy the BMC design which I think is really neat.
https://www.bmc-switzerland.com/au-en/i ... tegration/
thanks in advance.
Mark
Di2 socket mounted in SL6 frame port
I don't think the port is wide enough to accommodate the di2 handlebar charge port like the BMC or F10's.
If anyone does try they will need to strip the housing to probably even attempt to get it in. Let along another issue of clearance on the downtube with the etube wires.
