robertbb
by robertbb on Tue Jan 14, 2020 3:16 am
bm0p700f wrote: ↑Tue Jan 14, 2020 1:25 am
Also the camapagnolo more popular cassettes in 11 speed are 11 32 paired with semi compact or compact Chainsets.
The Campagnolo 11-32 cassette was released with the first generation (non-HO) Potenza medium cage derailleur, and it was labelled first as "Potenza" cassette and now as "Campagnolo 11". It has never been available as a Chorus/Record/Super-Record level cassette.
Are you saying this cassette has outsold all others? I find this very difficut to believe.
Kjetil
by Kjetil on Tue Jan 14, 2020 8:39 am
AJS914 wrote: ↑Mon Jan 13, 2020 5:46 pm
I've been a Campy fan all my life but I'm thinking that if Dura Ace came my way I might try it.
A Shimano 11 11-28 doesn't even have a 16 t. My guess is that the REALLY BIG IMPROVEMENT (gesticulation with a small hand applies here) with DA 12 speed will be the inclusion of a 16t cog.
- Moderator
by Nefarious86 on Tue Jan 14, 2020 11:12 am
Kjetil wrote:AJS914 wrote: ↑Mon Jan 13, 2020 5:46 pm
The Campagnolo crowd will be very upset with this nice flat range.
Sent from my SM-N976B using Tapatalk
Using Tapatalk
ultimobici
- in the industry
by ultimobici on Fri Jan 17, 2020 8:08 am
Working at a bespoke builder that sells more Campag than most shops, I’m in a position to comment on the split of cassette sales.
The vast majority of customers opt for 11-27 or bigger in Campag. Sram is almost exclusively 11-28 or 11-32 unless they’re on clearance, similarly with Shimano we see 11-28 or 11-32 rapidly becoming the default choice.
With chainsets it’s the same. 53/39 is so slow we can barely justify stocking it. More often than not we were selling them off cheap years later!
Ex team bikes always had 53/39 but invariably we would have to swap the chainset out for a compact or more recently mid compact. With the advent of single size spiders this has now become a simpler ring swap.
Bottom line is it is not financially viable to produce smaller cassettes for a tiny percentage of riders who “must” have a straight through block.
FTPWhor
by FTPWhor on Sat Jan 18, 2020 3:48 pm
Need help! I am buying Super Record 12 speed EPS Groupset. It comes with external junction box. I will most likely buy the Bar End Junction box for clean wiring. Do I need to buy addition specific wiring (like for Di2 bar end junction you nedd a Y connector)??
tarkus
by tarkus on Sat Jan 18, 2020 3:49 pm
i had to...at starbike they have an dedicated article for it.
whole set should come on monday
Gesendet von meinem LM-Q610.FGN mit Tapatalk
jgpallero
by jgpallero on Sat Jan 18, 2020 4:08 pm
Hi,
Apparently, Campagnolo only has 11-29 and 11-32 cassettes for their 12s groupsets. Until now, Miche has compatible stuff up tp 11s in order to personalize it. Anyone knows any other companies producing compatible Campagnolo cassettes? I'm looking for a 12-25 and 12-27 12 speed ones
ParisCarbon
by ParisCarbon on Sat Jan 18, 2020 9:00 pm
Yep.. the DTI and the cables are 2 seperate packages... the "Y" connector being talked about has one cable for the connection to the battery, the other one runs from the DTI, short end goes to your right ergo lever, the other end goes to the left ergo lever.. Campy's routing shows the cables all running outside the bars up to the levers, I have everything internal on both my Aerofly 2 bars... I just fed everything in from the rightside, used the cable magnet guide to "feed" things out... PITA yes.. but everythings inside..
https://www.campagnolo.com/media/files/ ... 19_ENG.pdf
