morrisond
by morrisond on Mon Jun 03, 2019 5:40 pm
keaton wrote: ↑Mon Jun 03, 2019 3:48 pm
Can a 140mm rotor be used on the front wheel of Campgnolo disc? I know Campagnolo says no, but was still curious.
appologies if this has been covered, couldn't find anything.
Campagnolo does not reccomend - but if you are light I don't see why not.
However you would not be able to do it with a Campagnolo front 160mm Caliper.
You would need a bike with a fork that takes 140mm Calipers that is through bolt like on an BMC Teammachine Disc and then use a Campy 140mm rear Caliper.
What bike is it going on?
That being said if you have a Conventional Road Flat Mount fork - the Campy 160mm Caliper is quite pretty.
keaton
by keaton on Mon Jun 03, 2019 5:52 pm
morrisond wrote: ↑Mon Jun 03, 2019 5:40 pm
Thanks!
working on somthing custom with a Columbus Futura Disc fork for road, or something similar.
I weigh 125lbs/57kg so was thinking a 140mm would be doable, I also always like the look of 140 rotors more.
Thanks for the info!
morrisond
by morrisond on Mon Jun 03, 2019 6:41 pm
keaton wrote: ↑Mon Jun 03, 2019 5:52 pm
Thanks!
Got it - I looked around but I don't think there are any Road Disc Forks that will allow a 140mm rotor. But I could be wrong.
That being said I still think the Campy 160mm Front Caliper is the most elegant front Caliper solution - you could always do 160f/140r.
Good luck!
hannawald
by hannawald on Mon Jun 03, 2019 7:32 pm
Any experience with new standard mount rim brakes? I have experience with previous generation direct mount brakes and they were really strong on Bianchi Oltre.
hannawald
by hannawald on Tue Jun 04, 2019 8:31 am
I currently have sufficient brakes on my bike, they are very light but a bit soft on the lever..i tried super record direct mount brakes on Oltre (previous generation) and you merely could not press the lever further than to half..seemed very powerful..wonder if this is the difference between brakes or direct mount vs regular mount..
Kjetil
by Kjetil on Tue Jun 04, 2019 9:06 am
I've only tried DM brakes once, on an Oltre XR4. IIRC the (pre production) setup was DA 9070 with Ultegra DM brakes om Vision Metron rims. They were quite "digital" in feel; I had to be a lot more careful with modulation than with the SR Skeletons and Shamals that I had myself at the time.
Boshk
by Boshk on Tue Jun 11, 2019 3:56 am
Record vs Super Record, the main difference is in the cult bearing in the crankset correct??
..and a little bit more carbon on the components......otherwise they are both the same?
How big of a difference are the crankset? .......price wise, its nearly 800usd difference
Nejmann
by Nejmann on Tue Jun 11, 2019 7:55 am
Nefarious86 wrote: ↑Tue Jun 11, 2019 6:19 am
Those rims are amazing on almost every brakeset
I wish we could buy blank rims and build them up.
Sent from my SM-G975F using Tapatalk
That would actually be really great.
Wookski
by Wookski on Tue Jun 11, 2019 10:34 am
Boshk wrote: ↑Tue Jun 11, 2019 3:56 am
They are “otherwise” not the same- they say SUPER. That immediately makes them 100x better.
WorkonSunday
by WorkonSunday on Tue Jun 11, 2019 10:56 am
am i correct that there is currently no way of using 12 speed on TT set up without going EPS ? thanks.
Some say pour 10ml water out of your bottle to save that last bit of the weight. Sorry, i go one step further, i tend to the rider off my bikes.
Miller
by Miller on Tue Jun 11, 2019 12:41 pm
There isn't a mechanical bar end shifter for 12sp, no. It might be do-able if you could find a non-indexed bar end with enough cable pull.
Bear in mind that TT frames often have long and convoluted cable runs that make e-shifting a better option anyway. The entry price of EPS 12 is painful though. Hopefully a chorus version will come through.
gorkypl
by gorkypl on Tue Jun 11, 2019 2:12 pm
The SR crankset is hollow, quite a big difference in weight...
Other than this, no significant differences between R12 and SR12 (I know, I know. SIGNIFICANT).
Cinelli Superstar Disc - Record 12s
