Campagnolo 12-Speed
Calnago
by Calnago
Well, I'm not going to say don't do it, but I will say that I wouldn't. And here's a thread you might like to have a look at...
viewtopic.php?f=3&t=137607&hilit=missing+link+campy
AJS914
by AJS914
I used KMC chains on 10 speed for years. I went with one immediately for 11 speed and I could never get it to quiet down. I swapped it for a Chorus chain and voila, perfectly quiet chain.
Kjetil
by Kjetil
This is a 12 speed thread.
Bianchi-Campagnolo
The Specialissima
Calnago
by Calnago
Good point. Thread drift. Rewind.
fogman
by fogman
Does the current Campagnolo 11 speed chain tool also work on 12 speed chains? Has Campagnolo released a new chain tool for 12 speed?
It's all downhill from here, except for the uphills.
Calnago
by Calnago
No new chain tool. The current Campy Chain tool is the tool of choice for 11sp and 12sp. And that’s per Campagnolo.
hannawald
by hannawald
Can you use 12 speed chainrings on previous 11 speed crankset? It should have same BCD..thank you. Any downsides doing that?
ultimobici
by ultimobici
I know the question about 2015 onwards 11 speed rings has been answered. But I’m wondering if conventional 5 arm 11 speed work ok? Trying to decide whether or not to sell my cranks or hang on Tj a pair for a SR12 or SR12 EPS build.
Butcher
by Butcher
I'm going that route [5 arm] when I get the EPS12. I look forward to the answer.
1llum4
by 1llum4
IIRC inner 12s chainring can work on 11s 4 arms crank and 12speed record outer chainring can work on 11s 4 arms crank but Super record 12s outer chainring is different because of the connecting bridge between the arms and should only work on SR 12s 4 arm crank.
flat
by flat
ultimobici wrote:
Sun May 05, 2019 8:41 am
I use a P2M type S an 11 speed crank with Stronglight Ct² 48-33 rings. I also use the newer 11speed [A] front mech.
It did not have enough travel sideways initially but I moved the cable down (on the mech) to get more travel and have more than 1000k
with it now. It works flawless. I did not bother with the cable adjuster Campagnolo shipped with the levers, it works perfectly fine without it.
Best Campagnolo shifting I ever had. (12 speed). However it is a mountain group, medium derailleur, big cassette with big jumps.
Not for the flatland's.
Also note this is mechanical ONLY. EPS, no idea how that works.
ultimobici
by ultimobici
So you’re using an 11 speed front mech and 11 speed non Campag rings with a 12 speed set up?
flat
by flat
Yes the ring actually says 11/10. And I use the newer 11 [A] front derailleur that I find works great even with the older 11 speed shifters.
I didn't buy a 12 speed mech because I was expecting to use my old 11 left shifter.
But the 12 works like a charm, I don't ever have to adjust the front mech when cross chaining.
Just move the wire down on the FD. The 12 speed FD might work but I never tried it.
welchy
by welchy
So I’m considering biting the bullet on Campy 12spd.
I will be going Super Record Hydro Mechanical (weirdly cheaper online than Record), Record front and rear Mechs as I have no need for that 200gs or whatever the saving is.
Can’t find any full groupos in the UK at the moment, only from Germany. Has anybody tried the new hydro brakes on 12spd. I will likely buy it this week but won’t fit until I find the frame I’m going to put it on. Either a lynskey r380 or a Aeroad (don’t ask why such different choices!).
Anybody got any advice before I bite the bullet?
dgdracing
by dgdracing
Hi the brakes are very nice. They are not as digital as the Shimano so there is less danger of accidentally braking too hard. And there are lots of 3rd party brake pads since it is essentially a Magura caliber.
