Campagnolo 12-Speed
Mockenrue
by Mockenrue
I don't understand - what problems are people having installing the C-clip with a P2M crank? I just use a flat blade screwdriver through the hole in the arm to gently push each prong into the hole in the cup. Very straightforward and takes barely any more time than installing a standard UT crank.
Sent from my VOG-L29 using Tapatalk
arkasha1965
by arkasha1965
Mockenrue wrote:I don't understand - what problems are people having installing the C-clip with a P2M crank? I just use a flat blade screwdriver through the hole in the arm to gently push each prong into the hole in the cup. Very straightforward and takes barely any more time than installing a standard UT crank.
Please, which model of P2max have you?
Inviato dal mio ONEPLUS A6003 utilizzando Tapatalk
Mockenrue
by Mockenrue
Type S, 4 bolt.
AJS914
by AJS914
Is the clip really a "safety" clip? The right side staying in the frame when the left side falls out seems like a small consolation assuming one is still upright.
usr
by usr
I'd say the primary safety is to protect the hirth teeth from accidentally getting loaded by the bolt in a misaligned position during installation which could probably make the link permanently unusable if you keep tightening until the prescribed torque. The clip acts as a third hand so that you can hold the other side with one hand while operating the wrench with the other. Beyond that, the only function is extra positioning if the wave washer happens to be extended (and thus compressible) wider than the wiggle room the drive side bearing has between cup and clip.
mag
by mag
I neither use the C clip with the P2M power meter as it's pretty cumbersome to work with it. No issues without it and the crankset installation & removal are much easier.
tomato
by tomato
mag wrote:
Fri May 14, 2021 11:29 pm
Yeah, I need to pull mine tonight to replace the battery; it's a lot easier when you don't have to fuss with the clip.
Mockenrue
by Mockenrue
What is cumbersome about it?
corky
by corky
AJS914 wrote:
Fri May 14, 2021 10:20 pm
It provides a stop for the drive side bearing, this ensures alignment for the chainrings with respect to derailleurs.
ultimobici
by ultimobici
It beggars belief that Campag spent all that time designing UT yet some people seem to know better than them. Probably the some are the same idiots who bleat about poor gear shifts or excessive bearing wear!!
DaveS
by DaveS
I can sure tell that most Campy users have a low level of mechanical knowledge. As a mechanical engineer, I understand the clip. It has nothing to do with safety. If it's removed, the crank can move far to the right, squashing the wave washer and unloading the right side bearing. The wave washer pushes the whole assembly to the left, preloading both bearings. Not using it is stupid. The clip keeps both bearings loaded and limits the possible side movement to a very small amount.
mag
by mag
Mockenrue wrote:
Sat May 15, 2021 8:36 am
In my case it's pretty well hidden so that I have to work with it sort of blindly. And the access it also limited. It may be better with frames using smaller diameter BBs where one could at least see things better, but I decided to not bother in my case.
@ultimobici @DaveS
I understand the clip function yet I still decided to omit it. I simply reserve my right to make some decisions, weighing up the pros & cons and giving up something for something else. If a serious problem comes up because of that I know why and I'm ready to blame only myself. :-P
AJS914
by AJS914
Thanks- "safety" clip just sounded implausible.
ghisallo2003
by ghisallo2003
The clip is intended to limit the lateral movement which is allowed by the compression of the wavy washer if the frame is at the lower end of tolerances, and the washer is not fully compressed. This is typically of the order of 0.25mm, which can, in some circumstances, have an impact on front changing, and if a rider has a particularly asymmetric style.
It is not normally a big deal at all to use it, but when using SRM and P2M Campag cranks it is harder and it is worth seeing if your frame and style do need the clip.
As a relevant observation, C-Bear UT BBs do not use the clip.
Butcher
by Butcher
As much force as the front EPS derailluer can provide, I suspect, without the clip, shifting to the big ring would not be as good. My clip is always installed and could not share what the difference are if it is not.
