I would do a rear mech zero reset in your situation, most likely this will fix it, doing a reset only takes a minute or two. I speculate that the interface memory can become corrupted with long uptime. I think it actually helps to turn EPS off with the magnetic band once in a while.Willy86 wrote: ↑Mon Oct 11, 2021 9:38 pmI'm having a problem with the rear derailleur of my SR EPS. Until yesterday everything was working fine, but now effectively the indexing has shifted 1 gear up; it only goes down till the 12t (while indicating it as the 11t in the app) and if I shift up completely it throws the chain off the casette. It is like the system remembered incorrectly the last position and now everything moved up 1 gear. Should I just re-index or can I shift / correct the indexing by 1 gear in some easier way?
Campagnolo 12-Speed
cycling / nature / music
- MrCurrieinahurry
- Moderator
Mines all sorted now cheers guys just needed a little fiddling with
should Iworry about the difference in diameter? The gear wire from Campagnolo has a diameter of 1.2 mm, while that of Jagwire is 1.1 mm.usr wrote: ↑Mon Oct 11, 2021 10:47 pmUnlike the Ultra Low Friction kit which supplied both brakes and derailleurs, the The Maximum Smoothness kit is derailleurs only. Welcome to the age of hydraulic brakes, prices habe been adjusted for your convenience.Shmitt wrote: ↑Mon Oct 11, 2021 7:34 pmCurrently, I'm just waiting for a custom-made frame and I've already completed the Campagnolo group. I have a question - where can I buy, if Ican buy at all, the gear cable? So far, I have only seen in the Maximum Smoothness kit, and I would like to buy only the gear cable.
(Or did you mean something else by "only the gear cable"? Inners only are listed in a very small number of online shops on the entire Google index, but the price will drive you back to the full kit. I'm currently on the highest grade Jagwire and I'm undecided about a noticeable difference)
Today I started to put my bike to its winter sleep, after 3 years and 18.000km the pulley wheels barely moved especially to lower one. Luckily the set for Record-12s is only 23€. Each year I kept using only one chain for around 6000km. Since the cassette is not "that cheap" I am wondering how I can determine its wear? I will regrease my 240s anyway so dissably will happen anyhow
Thats intresting. I have it on good authority that the 12s outer is identical to the 11s outer other than the silver writing is different. So basically you're using 11 speed cable and it works. I think the inner 12 speed cables are available seperatelyNickldn wrote: ↑Mon Oct 11, 2021 11:09 pmAs far as I know these Maximum Smoothness inners are not available separately.
To replace a cable which frayed I bought a 'normal' Campy inner gear cable for the RD, to use with a Maximum Smoothness outer. Works fine.
I think Jagwire make a 'lower friction' Campy compatible gear cable, which may be good too.
It's been a long long time since I've used mechanical group sets and even when I did, I ran them in a molested, mish mash state where they probably never fully functioned as intended (e.g. campy with sram cassettes).
For you on Campy mech, how often do you have a misshift or chain hesitates to shift?
If I have misshifts or the chain hesitates to shift it's because I changed something (chain/wheel/cassette) and it requires a touch of the barrel adjuster. Once properly adjusted practically never.RyanH wrote: ↑Wed Oct 27, 2021 5:54 amIt's been a long long time since I've used mechanical group sets and even when I did, I ran them in a molested, mish mash state where they probably never fully functioned as intended (e.g. campy with sram cassettes).
So you did 18.000km on one SuperRecord cassette using a new chain every 6000km? Would be good to know the reference. Thanks!dgdracing wrote: ↑Sat Oct 16, 2021 6:48 pmToday I started to put my bike to its winter sleep, after 3 years and 18.000km the pulley wheels barely moved especially to lower one. Luckily the set for Record-12s is only 23€. Each year I kept using only one chain for around 6000km. Since the cassette is not "that cheap" I am wondering how I can determine its wear? I will regrease my 240s anyway so dissably will happen anyhow
Ride bikes, not tanks!
Two 12 speed mech groups form campy and zero issues even once. Had many more with DA9100 and 9000 especially in cold weather.RyanH wrote: ↑Wed Oct 27, 2021 5:54 amIt's been a long long time since I've used mechanical group sets and even when I did, I ran them in a molested, mish mash state where they probably never fully functioned as intended (e.g. campy with sram cassettes).
Moots Vamoots RSL (2019)-Super Record 12
Cervelo S1 (2010)-Super Record 12
Kestrel RT700 (2008)-Dura Ace 9000
Mosaic GT-1 (2020)-SRAM Red viewtopic.php?f=10&t=174523
I did a search and read all the posts I could find in this thread, but it's still not totally clear to me:
Is there any functional difference in braking power/caliper stiffness between the new Record brakes and the Chorus skeleton brakes? All else being equal I'll just save the money and go Chorus.
