Campagnolo 12-Speed
Denavelo
by Denavelo
RyanH wrote:
Thu Dec 09, 2021 12:18 am
I ordered a Shimano splined Ztto 12s cassette for my Kickr ($57). It should be here soon so I'll report back how it works on the trainer.
I recently purchased a Wahoo Kickr, and the costs of buying a cassette and the Wahoo freehub, was the same or a little more than me building an 11s bike for the trainer. My buddy sold me a Neilpryde for cheap and I had a majority of the parts to build it up. I've been riding this bike on the road and I think I found a replacement for my Focus Izalco Max. This Neilpryde RIPS! Only I would build a bike for the trainer. haha
11.9 lbs of Trainer bike glory! :noidea:
Rob English "Mudfoot" 29er | Focus Izalco Max | Firefly #194 Stainless XCR | Firefly #277 | Neilpryde Bura SL 11.9 | Crust Evasion Lite
Butcher
by Butcher
I got a little Sunshine in the mail yesterday. 12 speed with a Shimano pattern. I hope this will work with my trainer, but still waiting for my EPS12.
The largest 4 gears are alloy. Fairly lightweight and at $42, it's going to be hard to beat. We shall see. The three screws hold all 10 gears together. The alloy gears are 1 piece. 11/29.
Sorry for the large pictures. I know, my camera sucks too.
itsacarr
by itsacarr
Can't wait to hear how it works.
Just ride ..
MrCurrieinahurry
by MrCurrieinahurry
Few grammes extra on that scale
Basso Diamante super record EPS 12
BMC slr01 ultegra Di2
Butcher
by Butcher
Yeah, tie wraps but if you understood my life, I would loose one of the pieces. This way, I will loose the entire cassette when it comes time to look for it, not just one piece.
Sucks to get old.
MrCurrieinahurry
by MrCurrieinahurry
Haha I meant the gunk on the scale
Butcher
by Butcher
That's clean! You should see my shop! If my clients see what I see, I would be out of business. :D
Since I pick up and deliver all my clients cars, what they do not see will not hurt them. All they see is that their Mercedes is in better shape when they get it back at a price that keeps them coming back for more.
Next time, I will promise to shine it up.
BikeNerd2453
by BikeNerd2453
Denavelo wrote:
Thu Dec 09, 2021 5:02 pm
Man, I lusted after that Bura SL when they first came out! I came so close to buying one, still wish I had. They were such rad bikes. Sub-12 for trainer duty, I love it! :D
RyanH
by RyanH
I won't be able to report back for awhile since my Ztto came with two 11t cogs Image
MrCurrieinahurry
by MrCurrieinahurry
frankton
by frankton
I am setting up Record 12. The chain is making very loud noises when I am in the low three cogs (25/28/32). Noises are there in the small (36 and also much louder in the 52). The chainline looks pretty extreme. Any ideas as to what I can do to make this better? I am assuming the noise is from the chainline.
Everything is to spec, chain length, limits, b screw....
DieselCondor
by DieselCondor
If everything else is in spec- check the hanger alignment and play around with the 'b' tension. Failing that and assuming that everything is shifting ok, I find that the chain will bed in and quieten down after a few hundred km.
LewisK
by LewisK
Is the axle the same on super record 11 and 12? I have a threadfit ceramic speed BB with a 12sp chainset, but changing back to 11sp chainset....so i assume i can use the same BB? Thanks!
mag
by mag
Sure, no difference.
ColnagoJohn
by ColnagoJohn
after fitting 12 speed mechanical record hydro to my winter bike i have now gone all in and sold the SRAM force axs off my scott addict rc so that i can get 12 speed eps on that bike.
My question is does anyone know which caliper i will need to buy to fit on the front of the addict rc? the normal campagnolo 160mm front caliper has the screws going through so they can screw into the fork bosses, but on the addict the fork is the same type of fixing as the rear caliper on normal frames ie the screws come through the fork and screw into the caliper directly.
On shimano and sram this just requires removal of the adapter bracket thing, but on campagnolo there isnt a bracket to remove so do i just get a rear 160mm caliper to use on the front too? sorry for the long winded wording but any help would be appreciated and i want to make sure i am ordering the correct parts
