Campagnolo 12-Speed
moonoi
by moonoi
I’m using the lock ring that came with the cassette, so shouldn’t be that, also the wheels are the same as from the CFR (Bora WTO), and again worked fine on that bike.
Hanger is straight also…
Bobbyc123
by Bobbyc123
moonoi wrote:
Fri Dec 23, 2022 4:57 pm
Are the the pulley wheels set correctly?
bikeboy1tr
by bikeboy1tr
I keep my pulley wheels as close as possible as long as its not catching the largest cog when shifting to it. Should good wrap if you are at least in the range of what is shown above.
viewtopic.php?f=10&t=154188
2018 Colnago V2R Rim Brake
2019 Colnago V2R Disc Brake
robertbb
by robertbb
Apologies if this has been asked before, I've tried searching and can't find anything definitive:
has anyone tried a Shimano 12 speed 11-34 cassette (105 level) with Campy mechanical 12 speed?
I ask specifically about the 105 level cassette because it's a "standard" Shimano cassette which I'm thinking will be far more "vanilla" in tooth shaping than the Hyperglide+ cassette.
moonoi
by moonoi
Seems to be set correctly and looks good to me
Big - Big:
And Small - Big
This is with the KMC chain that specifically mentions Campagnolo 12v compatibility
gorkypl
by gorkypl
robertbb wrote:
Sat Dec 24, 2022 2:01 am
All 12s road cassettes work with all 12s road systems, the compatibility is better than with 11s.
Fuji Cross 1.5 - Shimano 105 5800 | Cinelli Superstar Disc - Record 12s | Custom steel Karamba - Ekar 13s
gorkypl
by gorkypl
moonoi wrote:
Fri Dec 23, 2022 3:54 pm
Anyone had a problem with SR12 EPS slipping on the 11 cog, I’ve tried a new chain (KMC and Campy) and a new cassette and every time when putting out 200w+ the chain slips like it’s on a worn cog, but since everything is new I’m completely lost for where or how to troubleshoot this problem further. It’s installed on a Look 795 Blade RS, and taken off my old Canyon Aeroad CFR where it worked perfectly!
Note it doesn’t slip in any other gears just the smallest 11 cog…
Are you sure it is skipping on top of the cogs (like with a worn cassette) and not jumping to side (wrong adjustment) ? I would triple check hanger straightness and reset the limits - cannot think of a scenario when new Campy chain would skip on a new cassette other than incorrect adjustment. Perhaps incorrect pinning leaving a stiff joint - but it would limit the skipping to joined link only.
robertbb
by robertbb
gorkypl wrote:
Sat Dec 24, 2022 8:55 pm
Wow, cool! Has anyone actually done any measurements of the cassettes for comparison? (there was a very detailed thread previously comparing SRAM and Campy 12 speed cassettes, but not Shimano.
Miller
by Miller
I am thinking a campagnolo chain would solve the skipping issue for moonoi.
moonoi
by moonoi
Miller wrote:I am thinking a campagnolo chain would solve the skipping issue for moonoi.
I swapped the original SR chain for the KMC chain in an attempt to resolve the problem, but have the same issue, as the LBS didn’t have any 12v campag chain in stock.
I’ve ordered one on line and see if it makes a difference (strangely a new joining pin costs almost as much as an entire chain here!)
Miller
by Miller
Well, good luck, the sprocket jumping must be very annoying.
JoO
by JoO
I am aware that user DaveS says his chorus shifter and rd work very well with sram axs casettes.
However, I asked ratio technologies if their axs compatible ratchet would work with campagnolo cassette.
This was their answer:
“ … unfortunately we really can’t recommend using the Campagnolo 12 speed cassettes with our upgrade kits. We’ve measured the Campy cassettes before, and the sprocket spacing is quite significantly different to SRAM’s cassettes so it won’t work well.”
robertbb
by robertbb
JoO wrote:
Mon Dec 26, 2022 7:47 am
Yep. DaveS also subsequently posted that he moved to full AXS drivetrain.
ice29
by ice29
Hi, I am thinking about buying the Power2Max crankset to get powermeter for my SR12 EPS... Now can I simply move the SR chainrings to the P2M crankset? or are the SR12 chainrings "special" and they only work in SR spider?
I have checked the Campy pdf drawings and while the chainrings for SR and RE have different part-numbers they look the same to me...
joeyb1000
by joeyb1000
I don't know anything about Ratio Technologies stuff, but I've measured Campy and AXS cassettes with calipers and found no difference. Also, I ran an AXS derailleur with a Campy cassette and chain, and the shifting was great.
