Campagnolo 12-Speed
Kjetil
by Kjetil
I’ve been thinking that Ewan just doesn’t like a 16t in there. A 27t instead of a 26t and 29t sounds far fetched but who am I to judge? Lots of people put sram on their bikes, right?
Bianchi-Campagnolo
The Specialissima
Gylne Gutuer, the UCI 1.2 bike race I invented.
micky
by micky
AJS914 wrote:
Thu May 13, 2021 12:20 am
tomato wrote:
Wed May 12, 2021 6:42 pm
Yeah, it's a weird reason. But, does it really matter why he prefers what he does?
When a guy who wins grand tour stages wants very specific equipment, we want to know why.
Example, Viviani is using black sheos + white socks because.......that's the combo that made him win a TdF stage.
WorkonSunday
by WorkonSunday
Kjetil wrote:
Thu May 13, 2021 7:55 am
yesterday he averaged 12seconds 1200w and he's only 16xcm, he cant be that heavy ! :beerchug:
Some say pour 10ml water out of your bottle to save that last bit of the weight. Sorry, i go one step further, i tend to the rider off my bikes. :thumbup:
n+1...14 last time i checked, but i lost count :mrgreen:
Kjetil
by Kjetil
He’s a phenomenon all right. His ride over the Poggio this March was maybe the most impressive I’ve seen by any rider, male or female, this season.
Bianchi-Campagnolo
The Specialissima
GS100
by GS100
I saw this on my Google feed so commented on the other thread about the old close ranges.. (then realised it the article was 4 months old and already covered in 2021 pro equipment thread!).
Reasoning about 27t does seem fishy, I mean if you wanted a close ratio as a sprinter you'd go for 11-23 or whatever. Nevertheless 29t does seem overkill. More choice please, listen up Campagnolo!
Butcher
by Butcher
There are just a few super flat races but I would think an 11-23 would not be used a lot. I certainly could see an 11-25 or an 11-27 useful for flatter races. On the hilly routes, the 11-32 seems more likely.
barbaar
by barbaar
So who's rinding without the clip-that-nobody-really-understands? It's a pain to get into place with p2m cranks. So would be happy to just skip it...
And has anybody ever tried adding two wave washers to add spring tension?
Fuctor Ostro - Campy EPS SR Disc 12sp/P2M NG
Ridley R12 - Campy EPS Record 11sp/P2M NGEco
Thrust something - Campy Chorus/Record mechanical/P2M NGEco
No, that's not a typo
Miller
by Miller
I have given up using the clip-that-nobody-really-understands as I trust the UT centre bolt.
One wave washer is sufficient. Campag has done the thinking for us, just go with it.
Shmitt
by Shmitt
I'm in the process of completing the campagnolo record,
what kind of chain and cassette to buy? chorus or super record? I was thinking about buying a super record chain and a chorus cassette.
barbaar
by barbaar
SR is a little lighter because of some titanium sprockets. It mostly shows on the price tag..
I personally always ride with KMC chains. Think Campy chains still don't come with a quick link?
Shmitt
by Shmitt
barbaar wrote:
Fri May 14, 2021 4:08 pm
this is another thing, Campagnolo still does not use pins in 12s chains, and I would like to have the opportunity to remove it for waxing. are chains other than campagnolo worthy of attention? or maybe you have some proven chain links for campagnolo?
Guardian
by Guardian
I use Chorus cassette and SR chain on my Record build. Chorus cassette is far cheaper but the SR chain is only a few dollars more than Chorus. SRAM eagle quick-link works perfectly.
usr
by usr
For 12s it's all steel, just happens to have slightly different surface treatment on the machined blocks. And the machined blocks have more of the steel removed compared to those of Chorus, the weight difference. Arguably the monetary penalty for going SR is less that way, as the price difference isn't multiplied by increased wear. If your happy point on the budget axis happens to be right between Chorus and SR, you might consider Recon/Edco Monoblock which saves another hundred or so grams over SR by carving out even more. Shifting is noticeably different, but I don't know which one I prefer.
SR chain seems to last forever on my build (seriously, it's unreal!), must be because carbon rim breaking surface provides ample motivation to take the other bike for questionable weather.
Shmitt
by Shmitt
Guardian wrote:
Fri May 14, 2021 4:48 pm
Thank you for the answer, I think this is what I was looking for.
I don't want to use parts other than campagnolo. Besides the quick link.
tomato
by tomato
barbaar wrote:
Fri May 14, 2021 3:53 pm
I don't install the clip on my Power2Max crank, and I haven't noticed any issues.
