Campagnolo 12-Speed
You need SR for that lol.. Then maybe that's what Campagnolo want you to think as 12s Campagnolo has gone a bit porky, new Record 12 is kind of downgraded, almost = old 11s Chorus
As for Ultegra, likely around the same weight once you factor in the bearings are included in Campa's crankset weights and the cups are lighter than the various shimano 'sleeve' type BB options. Would hope Record would be stiffer too!
I want to make the wheels on the duke sls2 clincher rims. It turns out that the outer rim width is 27.6 mm and the inner 21 mm.
My question for experienced users - will these rims be compatible with the new record direct mount rim brakes, or with the central mount?
- jdecraene85
Sorry for the very late reply.bruno2000 wrote: ↑Tue May 18, 2021 3:18 pmThank you for th einfo.jdecraene85 wrote: ↑Tue May 18, 2021 1:21 pmThere is a little bit of talk about this on pages 257 and 258 of this thread, with a picture.
I purchased the Sigeyi DM rear derailleur hanger and the required Campagnolo screw kit (very hard to find, item code RD-SR105), only to find out only the mechanical version can be converted to direct mount and not the electronic version.
Well, I'm not 100% sure, but my SR EPS 12s rear derailleur is on the way too, so I'll find out soon if I still have any use for the DM derailleur hanger and that screw kit...
I bought a Sigeyi hanger too for my Pina F12.
Would there be a way around the extra screw?
I don't believe there's a way around... Often there's no alternative for Campy parts at the home hardware store.
But since I cannot convert my SR EPS 12s rear derailleur to direct mount, I have a new, unused RD-SR105 screw set lying around... Contact me if you're interested.
I've ridden Campagnolo 12v eps and mechanical with Rotor crank and dm chainrings. No problems at all.
That's what the screw set is for: Campagnolo put the block against which the spring tension adjuster screw is set (the screw commonly referred to as B screw, even if it's numbered Q in current manuals) at a different angle in their link part that emulates a DM hanger than the block on common DM hangers. That adapter screw is able to deal with the "Shimano angle" block.
Note that only mechanical are direct mount capable, the EPS version cannot be converted.
Sorry, what do you mean for DM chainrings?bruno2000 wrote:I've ridden Campagnolo 12v eps and mechanical with Rotor crank and dm chainrings. No problems at all.
Inviato dal mio ONEPLUS A6003 utilizzando Tapatalk
OK. Thank you!Do you, or anyone else, have a link to a picture or a video? The Campag manual only shows hot to convert the RD with the new screw. But I havent found any installation to the DM hanger.usr wrote: ↑Wed Jun 23, 2021 10:43 amThat's what the screw set is for: Campagnolo put the block against which the spring tension adjuster screw is set (the screw commonly referred to as B screw, even if it's numbered Q in current manuals) at a different angle in their link part that emulates a DM hanger than the block on common DM hangers. That adapter screw is able to deal with the "Shimano angle" block.
Rotor DM q rings are 2 chainrings 50-34 for example together made as one piece which are directly mountain on to the axle.arkasha1965 wrote: ↑Wed Jun 23, 2021 10:44 amSorry, what do you mean for DM chainrings?bruno2000 wrote:I've ridden Campagnolo 12v eps and mechanical with Rotor crank and dm chainrings. No problems at all.
No more chainringbolts to mount the 2 chainrings onto a spider.
