Hey WWs
Found this on "ebay" where I live and I'm thinking of replacing my 8+5 alloy topcap and carbon spacer with this full carbon cone shaped one.
Are these weights any good? These are cheap items but if they don't beat the alloy ones there's not much point buying.
I'm considering the 15mm one.
/a
Carbon headset top caps - are these weights any good?
Delrin plastic would be close to half the weight. Look at the Extralite spacers.
or Point 1
- Parlee Altum + DA9150 + Enve SES 4.5 Ene carbon hubs
- Parlee ESX + DA9150 + THM SRM PM + Enve SES 7.8 carbon hubs
- Moots Vamoots Disc RSL Titanium + DA9170 + Enve 4.5AR CK CL hubs
- Argonaut Spacebike 2.0 + DA9170 + Enve SES 5.6 DT Swiss 240 CL hubs
3d printed custom height spacer/top caps with a hollow cavity could be pretty light.
They look like bearing covers and integrated spacers rather than just spacers.
You could get a low profile cover e.g. Veloflyte/STS then add the lightest spacers you can find. The point ones were superlight, they changed their name but can't remember what to just now. Bear in mind they taper in at the mid point, so if you need to use more than 1 it might look weird. I have a 5mm one kicking around @ about 1.3g.
The Tune magnesium and Extralite would be the next lightest I reckon. I have a a Tune one kicking around somewhere. The smallest one is 2/3mm and only 0.7g. Good if you want to run a spacer above the stem.
- Similar Topics
- Replies
- Views
- Last post
3T Arx Ltd Stealth Carbon Road Stem in 120mm Weights?
by bikeboy1tr » Fri Jan 25, 2019 11:41 pm » in Road - 3 Replies
- 168 Views
Last post by bikeboy1tr
Sat Jan 26, 2019 12:16 am
- 3 Replies
- 541 Views
Last post by Wheever
Wed May 23, 2018 5:22 am
- 6 Replies
- 533 Views
Last post by boots2000
Mon Dec 10, 2018 6:40 pm
- 23 Replies
- 1991 Views
Last post by liam7020
Sat Nov 17, 2018 12:24 pm
- 1 Replies
- 325 Views
Last post by danbjpa
Sun Sep 23, 2018 8:49 pm
