Rattling from DT Swiss 240 rear hub??
xcnick
by xcnick
I’ve only done a handful of rides on my DT Swiss PR1400 wheels with 240 hubs, but today a light metallic rattling, or ‘jingling’ started on my bike. I stopped and spun the rear wheel and it was coming from the hub-made no difference whether it was freewheeling or pedalling. It then stopped and started intermittently for the rest of my ride.
Now home I stripped it all down which takes seconds, to find nothing! No borken spring, nothing!
Anybody come across this??
kode54
by kode54
could be valve stem rattling within rim valve hole? carbon tends to reverberate throughout, so difficult to track down noise.
- Parlee Altum + DA9150 + Enve SES 4.5 Ene carbon hubs
- Parlee ESX + DA9150 + THM SRM PM + Enve SES 7.8 carbon hubs
- Moots Vamoots Disc RSL Titanium + DA9170 + Enve 4.5AR CK CL hubs
- Argonaut Spacebike 2.0 + DA9170 + Enve SES 5.6 DT Swiss 240 CL hubs
xcnick
by xcnick
Definitely not the valve noise. The rim is alloy not carbon too.
It was coming from the hub, imagine a little bit of metal jingling around in the hub body. I was expecting to find a broken spring or something. It wasn’t related to speed or whether I was pedalling or not. Cassette was tight too...
alexmcm09
by alexmcm09
It's probably the non drive side end cap. I find that with any sort of moisture on the wheel (i.e. roads have been wet) it spins around the axle making contact with the hub shell, making a metallic jingling. It drove me crazy trying to figure it out, I thought the was a peice of metal loose in the rim. I just pack it full of grease and it quiets down.
xcnick
by xcnick
alexmcm09 wrote:
Sun Mar 11, 2018 10:41 pm
I knew someone here would have the answer!! It was very wet today and started after about 7 miles. It’s the first time I’ve ridden them in the wet. I’ll grease it up and hopefully not hear it again. Thanks so much, I would have never found that!
alexmcm09
by alexmcm09
xcnick wrote:
Sun Mar 11, 2018 10:50 pm
Happy to help mate. Hope you're enjoying the wheels, I absolutely love them. Just make sure to keep your brake pads clean, as embedded debris can and WILL cut through the black ceramic coating. Despite the hardness of the ceramic coating they are definitely not designed for a rough UK winter.
xcnick
by xcnick
Yeah I am enjoying them. They’re not winter wheels or on a winter bike, I’m just sick of riding the proper winter bike and was dying to get out on something nicer and the weather was absolute crap this weekend!
I’ve always used the blue swissstop pads anyway and do try to keep them clean, but thanks for the heads up.
The actual rim itself (not the brake track) is pretty fragile-the rubber coated wheel hooks that I hang my bikes on has started to wear the black off! That’s the only negative so far
