Mileage Specialized Turbo Cotton?
nemeseri
by nemeseri
I used the 24mm on the front and 26 on the rear. I got a little bit more than 1000km out of the rear one when I started to get flats 2-3 times a week. It's a great tire, but I stopped using them because life is too short to spend time with fixing flats on the road side. :roll:
The 28mm version might be a bit thicker, but I won't put a tire on my bike that baloons up to 30mm+.
mattsurf
by mattsurf
nemeseri wrote:
Sun Mar 11, 2018 3:53 pm
That is a little unfortunate, I got loads more miles out of mine (28mm). However, if I was getting 2-3 punctures per week I would also change tyres, no question
My Calipers show 28.3mm on Reynolds Assault rims
dim
by dim
depends what you are after ...
if you want very fast comfy tyres get the Specilized Turbo cottons
if you want puncture resistance, get Durano Plus, or Conti 4 seasons
I dont mind paying a bit extra for speed and comfort, but if you only get 1000Km on a turbo cotton, what do you weigh? .... I get closer to 2000Km before they start wearing thin
these are the best tyres that I have used, and I don't mind paying for them
Trek Emonda SL6
Giant TCR
CrankAddictsRich
by CrankAddictsRich
dim wrote:
Sun Mar 11, 2018 7:26 pm
I'm of the same mindset... I'd much rather have the satisfaction of using great tires.. the feel, the speed, etc and the expense of maybe having to fix a flat 2 times a season. I've used the S-Works Cotton Turbo and also the S-Works Turbo. I've found the Vittoria Corsa G+ to be a perfect blend between the two in terms of performance and durability.
2016 Pactimo Brand Ambassador
http://www.Crankaddicts.cc
2017 Specialized S-Works Tarmac SL5
2015 Specialized S-Works Allez
2014 Specialized S-Works Shiv TT
2015 Specialized Venge Pro (Retired)
nemeseri
by nemeseri
My weight is 129lbs. Personally I found the vittoria g+ tires have slightly better millage and slightly better puncture protection in dry conditions. I will probably go back to conti gp4000s for the wet season. Maybe I had super bad luck for two weeks, but during fixing my 5th flat in 10 days I swore I wouldn’t put on Turbo Cottons again. And yes, I found the cause of the flat every single time.
And you are right. Every area and every rider have a preferred blend between puncture protection and speed. For the roads I ride on, I found the TCs to be too fragile and expensive.
spdntrxi
by spdntrxi
you guys are skinny compared to me.. I'm 185lbs... love the TC's my only flat was a piece of glass.. the rear will do over 2000miles for me and then some. Trust them in the damp too.. vs Corsa G+ speed that flat out scared the hell out of me in the wet.
CrankAddictsRich
by CrankAddictsRich
spdntrxi... interesting. I don't have that percepion of the Corsa G+ in the wet, at all. I can't complain about the TC's in the wet either.
spdntrxi
by spdntrxi
CrankAddictsRich wrote:
Mon Mar 12, 2018 11:46 am
I had one ride.. almost lost it in one turn (rear slideout,not braking) and another turn totally went straight through into a dirt bank but stayed upright. That was enough for me. This was not a new road to me and one I've taken in the wet before.
Hexsense
by Hexsense
I found not only weight determine durability. But also pressure.
High pressure put tire under more stress and less flexible condition. An object that low pressure tire would deform around normally could pierce through the the same tire at higher pressure. Also the center thread wear down faster with more load concentration in the center with higher pressure too.
Weight and pressure needed are weakly linked together, it's ultimately rider's choice to select the pressure.
I found Vittoria Corsa G+ rock in dry and wet grip if it is clean and have broken in for at least 40km. However, their compound really likes to pick up small rocks when wet, maybe their compound is too grippy or soft? i don't know. but those small stone/debris they pick up not only slowly pierce through tire if i roll them for long time but also reduce grip since we are rolling on sand/debris rather than rubber. That was my perception with the normal Corsa G+, not Corsa Speed G+ which supposed to have less grip.
Rather than go to Continental GP4000sII i now testing Continental GP Attack III and GP Force III - 23c and 25c combo. They use the same Vectran Breaker and same Black Chili compound as 4000sII, just thinner and construct a bit differently. They run a tiny tiny bit narrower than Conti 4000sII of the same size label. No test result from labs yet (http://bicyclerollingresistance.com/ tested version II which is 22c and 24c). So far i found them perform well after initial break in.
spdntrxi
by spdntrxi
I was on Corsa G+ Speeds
CrankAddictsRich
by CrankAddictsRich
spdntrxi wrote:
Mon Mar 12, 2018 4:59 pm
Ahhh... that makes sense. That is a TT tire. It is what I use for racing time trials. I don't know if I'd be smashing turns on it in the rain.
spdntrxi
by spdntrxi
Mon Mar 12, 2018 5:35 pm
yeah they where put on my TT bike the next day. :mrgreen:
but a turn smasher I am not. It was fairly mundane speeds which is why I didn't crash out.
Hardstyle
by Hardstyle
Marin wrote:
Sat Mar 10, 2018 12:17 pm
https://fairwheelbikes.com/specialized- ... tton-tire/
Fairwheel have them
Thanks.
