Minimalist, light weight k-edge mounted lighting
Mr.Gib
by Mr.Gib
I have searched but it seems like most of the options are way more then I need. I am not looking to replace the sun. I just need a rechargeable small front flasher that I can mount under my garmin. I just need to be seen. I will not be riding at night.
Any ideas.
by Nefarious86
Light and motion with a gopro attachment Image
Sent from my SM-N950F using Tapatalk
Using Tapatalk
naylor343
by naylor343
Exposure trace. It's tiny and in daybright mode, nobody is gonna miss you coming
Mr.Gib
by Mr.Gib
Nefarious86 wrote:
Mon Mar 05, 2018 7:54 am
This is exactly what I am trying to avoid. That's a lazer cannon.
naylor343 wrote:
Mon Mar 05, 2018 11:19 am
I have lots of handlebar mount options. Looking for under Garmin/K Edge mount style.
TonyM wrote:
Mon Mar 05, 2018 6:55 am
https://fabric.cc/wp-content/uploads/20 ... 50x750.jpg
https://fabric.cc/products/lights/lumar ... ont-light/
Available next month in Canada I have been told...
Jackpot but.... under the Garmin would be better and the battery life on the lowest setting is bit lacking.
Mr.Gib
by Mr.Gib
Double post.
Mr.Gib
by Mr.Gib
Double double post. :oops:
Mr.Gib
by Mr.Gib
Triple double post? gotta be some sort of record. Wtf is with my browser?
naylor343
by naylor343
It's easy to mount a trace under a Garmin, take a look at the raceware site.
hmai18
by hmai18
https://www.trekbikes.com/ca/en_CA/equi ... Code=black Blendr mount should be Go-pro compatible.
http://www.lezyne.com/product-led-sport ... p2BAejwbGg Looks like you can replace the rubber band mount with a Go-pro interface, but that'll be an additional purchase.
TonyM
by TonyM
Other "minimalist lights are the Knog "be seen" lights:
I use the Blinder mini dot:
https://www.knog.com.au/bike-lights/be- ... i-dot.html
and have also the following lights for more power in case....
https://www.knog.com.au/bike-lights/be- ... hippy.html
https://www.knog.com.au/bike-lights/be- ... niner.html
hmai18
by hmai18
I'm not sure how small you're hoping to go, but I don't know if you're going to get exactly what you're looking for.
Blinkers/be-seen lights are typically going to be run as flash/strobes, so they're not going to need a huge battery to get decent run times. Without the need for a huge battery, there's no incentive for a manufacturer to increase the size/cost to put it in a more complicated housing that's go-pro compatible when they can put it in something held on with a silicone band.
stockae92
by stockae92
I have the mini dot front and rear, and they works great as just minimalist blinkers.
The front dot its pretty much useless as a "real" light in the dark as expected, but they both works good as a "to-be-seen" light
I recommend them. I actually use the front dot as my night runs light as well. I can wear it on my finger like a ring and it does a good job as a blinker, and do a much better job in the dark then riding because of the much slower speed. but still, lights are limited.
I wonder how much better is the mini chippy and mini niner, though they are rated as the same output (lumen)
TonyM wrote:
Mon Mar 05, 2018 11:06 pm
stockae92
by stockae92
Found my own answer here:
http://www.londoncyclist.co.uk/knog-bli ... ni-review/
stockae92 wrote:
Tue Mar 06, 2018 1:47 am
